I bought one. Antek actually offered a different one first, which I bought and recently built with toroidal iron.
I ran into some problems with the first one which is documented on diyaudio.com in the tube section but finally got it to run after purchasing a better PS transformer. Still could not make it perform like a 35 watt per channel ST-70. Right now I have it putting out around 25 watts one channel at clipping. As far as I am concerned the boards with this kit are nothing but trouble. I could not get it to run with the supplied driver board. PS board is OK. Might have to do with the inadequate PS transformer included with the kit when I tried to use it. No documentation or voltages on the schematic. I have my doubts the designer ever built the amplifier with the supplied PS transformer. I bought a larger PS transformer and the VTA 12AU7 driver board and finally after weeks made a successful PP EL-34 amplifier. I would not recommend the toroidal kit. Sounds good with good numbers now during testing but it was a struggle for a hobbyist like myself to get it to run.
The new kit appears to be using the same iron as the VTA Dynaco ST-70. I hope so. If so it will be a good deal.
