Thanks, but that should not be the problem. If it is there is other problems elsewhere being the original Dynaco uses a much smaller resistor 1K ohm in the feedback circuit with no problem, lots of feedback, whereas I am using the VTA board with way less FB using a 6.8K resistor. That and it is stable with slightly less bias, 30ma vs 40ma on the tubes. My thought if it were in the FB circuit it would oscillate no matter the bias setting, with some current naturally. For now, after fooling with this build for close to 2 months, I am ready to just listen to it for awhile.If you want to determine whether the oscillation is due to unstable NFB loop, simply disconnect it temporarily and see if you can bias the amplifier to 40 mA with the loop open. Then you’ll know.
Dave
I appreciate your suggestion though. Input is always welcome.
