the 5AR4 is overloaded in an ST70 anyway so no great loss.
Roy Mottram sells a solid state power supply board that mounts nicely underneath of where the stock bias pots go, using 2 stock hole locations. I think one was the original selenium rectifier, other is maybe a cable clamp? I made a tweak to his parts list, the 3 amp CL80 that is specified as a thermistor doesn't see anywhere near enough current to warm up and drop resistance. I changed it to a CL120 (I think, have to look) which is still overkill but less-so. Also higher cold resistance so its a slightly softer startup.
I changed the specified diodes too, it calls for a UF4007 which is 1KV PIV. I had something else on hand that I can't recall the number of which are good for 1.5 KV PIV, close to the original 5AR4 rating. If I didn't already have whatever those are, I'd have done a pair of 4007 in series and called it a day.
my setup is rather different since its Eico iron and not even an EL34 amp, but its in a Dynaco chassis and using some Dynaco bits so I could shortcut on the design process somewhat.
