Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
STAX DMA-X2 Monos
Epic sound and performance. 600wpc @8ohm, 1.2Kwpc @4OHM. Class A output stage, Class H power rails
These things are HUGE!! One dwarfs my MX-10000 Yamaha, which is already no slouch for size.
No tear-down yet because they work so well and sounds so good, but making that cap replacement inventory soon.
There are some relays that must be replaced but they are not common models, so hunting....
Big class A, these would cost about a grand a year to have them at idle ready to play. More than some replacement tube sets for that kind of amp of way less power. But both have operating cost we can see and feel. Not like those receivers many here like to use.
You miss the part about the Class H power supply / rails.
The power supply in itself is a class AB amp without global feedback. Its job is modulate the power rails at all times, in reference to the output.
Some "savings" on the electric bill but still with a fixed Class A bias, no adaptive stepping like the Krell you mentioned. The Stax is always at full bias Class A. The cherry on the cake is that it is a fully balanced design with zero global feedback, which is impressive by any standards considering the power specs. We usually see these features in much smaller amps.
No worries. I was not aware of this either.
Class H has nothing to do with the output stage. The output stage can be A or A/B, with the power supply being class H.
Stax uses something called SDPP (Sustained Differential Push-Pull) Stax's proprietary Class H-derived tracking supply, where the rail voltage follows the signal envelope. This keeps the output transistors operating at a relatively low dissipation regardless of output level.
Loved my time with a pair Stax mono’s just like yours. One of my all time favorite monoblock amplifiers that I truly miss as having around. Great if you can work on them yourself as they do require some maintenance at this point. Enjoy them in excellent health.
