Sticky Surrounds
davegiul
I have a pair of PSB Imagine B speakers. They are 9 years old. The surrounds have become
"sticky" over time. Is there a fix? TIA!
What material are the surrounds made of? Foam, rubber, are they accordion type, or what?
I ask because the only sticky surrounds I've seen were accordions on some 15" CTS woofers from the early 70s.
I've had some speakers in the past with rubber surrounds that got sticky. Still worked fine, but I can't remember what they were. I used rubber conditioner (for laser printer pickup rollers) and it fixed the stickiness, and didn't seem to affect the sound. Those surrounds look to be foam, though, so I wouldn't try this on foam.
Pretty sure those have rubber surrounds. You didn't by chance use any kind of cleaner on the surrounds at one point ?
Those are beautiful Imagine B's
I have some PSB Imagine mini's. All of the rubber case parts are suffering from plasticizer separation. The surrounds seem ok -- but that rubber collar around them is sticky. There are many complaints about this to be found. At one point they sold replacement case parts. I wrote asking advice for this and they suggested using a "residue-free electronics safe degreaser." For speakers of the caliber of the Imagine line, they really should have some more definitive suggestions about care. Some of those Imagine tower were designed and priced as a lifetime buy.
I've used isopropyl alcohol on one--as per a YouTube review of this speaker. It works well for getting rid of the goo--the plasticizer that migrated to the surface.
I would be nervous about using it around the driver for fear of setting off a chain reaction in the surround.
I have no idea what it will do to the rubber long term.
I'd welcome advice on if there is any treatment that could heal this problem once the sticky migrated plasticizer is removed.
I bought these used, so I don't know whether they were sprayed with furniture polish or cleaner. But it seems to be a common problem.
old 'foam' surrounds get sticky right before they crack and flake apart
in my experience....
