Studiomaster Mixdown Classic 8 Console Problem
apauly
Hi! I've been working on a Studiomaster Mixdown Classic 8. I opened it up to make sure the levels were selected properly (i.e. balanced +4 dBu). In order to open the console, you have to take out the entire board, not by channel strip. In doing this, I accidentally pulled some multipins in the midi section and placed them back where I *thought* they went. I consulted the service manual and I think everything looks right (there are some open pins). Well, the console turns on fine, but every channel mute light is on and when I press both the channel on and clip/listen buttons, the clip/listen led comes on. I should also not that the meters don't seem to respond to any input, and nothing seems to be functional. Does anybody have an idea as to where I should look?
Hello. First thing to check is the power supply rails. Check all the rails have the right voltage. It could be you shorted something and blew some fuse or voltage regulator.
