Subwoofer/amp issues
Why would you rewire it when you can just change the settings in the reciever and make it work?
For 2-ch with sub....
Front speakers = large
Center speaker = none
Surround speakers = none
Back speakers = none
S woofer = yes
Sw mode = +Main
Cr.over = 80Hz
Be sure the analog signal is going into a "normal" analog input like CD, DVD, etc., but not the EXT. IN terminals. EXT IN won't pass a signal to the sub unless you specifically have a signal to the EXT IN SW jack.
Ensure mode is Stereo, although the manual says Direct should work too.
The OP tried and couldn't find a way to make it work. Any idea where his settings might be off?
edit: ^^^OK, hope that helps^^^
S woofer = yes
Sw mode = +Main
Cr.over = 80Hz
Those are my settings exactly.The analog input is going into CD, and mode is stereo. i get no output from sub out, so where should the sub be plugged into?
So, running extra wires from my speaker outs on the amp didn't really work either.
With the music at lowish levels I have to turn the volume on the sub to about 3/4 to notice any difference in bass.Then if I turn the amp volume up the bass becomes overblown and horrible. So I am back to square one
This is weird because when I first hooked it up again i used some shitty old cables from amp to sub and sub to speakers, and dont remember having this issue.
Ill do that again to double check.
With the extra wires from the speaker outs I have changed the setting from subwoofer:yes to subwoofer:no and that seems to have improved the bass from the sub, i think.
The sub should be plugged into the "Pre Out Subwoofer" jack, from what it looks like to me.
With the sub setting at NO all the bass signal is fed to the main speakers, so that seems to make sense. I wonder if the sub out on your amp is simply fried?
edit: @whoaru99 - never even thought about the signal cable! (slap forehead)
We're probably going to have to stick to working one way or another, not jumping back and forth.
If you want to work on the speaker level connections you have plenty of help there.
If you want to work on the receiver settings and sub connection, I'm willing, but I don't want to play in between the two.
Your call (but regardless either way I'm off to bed soon).
Are you sure the RCA cable to the sub is good?
Are you sure the sub level in the receiver isn't turned way down?
Have you done the factory reset a couple times then reconfigured from scratch?
In case there is any doubt it should work, here's the matrix showing it.
attachment.php
If settings and such don't seem to be doing what they're supposed to do, there's always this. In the case of problems it's often the first thing I recommend to flush out any old cobwebs and settings. Do it a couple times for good measure.
attachment.php
Well at least by jumping back and forth we can be sure the sub works. :worried:
Please continue helping, I really appreciate it.
I have just run a digital signal into the amp and the subwoofer pre out and RCA cable work as they should.
I will try a factory reset.
I have reinitialized the receiver 3 times, redone all the settings and nothing has changed, still no output via the sub pre outs with analogue sources.
Perhaps that's a misprint in the manual.
You can use two of these on your source and feed the sub inputs and Denon inputs simultaneously. The sub and Denon volumes will have to be adjusted independently. Can do the same with your TPA3116.
I suppose it's not impossible it's a misprint, but the analog inputs (except multichannel EXT IN) normally are digitized to facilitate the bass management for matrix surround modes. Maybe we'll try that angle in a bit.
After the source/input is selected (e.g. CD), how are you selecting the input mode; leaving it in Auto, selecting Analog, or selecting Direct/Stereo?
Out of curiosity, even though you may not even have them connected, what happens if you enable the center speaker and surround speakers?
After doing the above, what happens if you change the mode from stereo to, say, Dolby Pro Logic II music mode? In the latter, you may get a a phantom center channel effect. Find the Center Width parameter and set it to 7 which will eliminate the phantom center channel width effect (leaving just plain L/R stereo).
Normally when I select the source i don't do anything regarding selecting the input mode as the receiver "remembers' what the input mode was last time. I have however, due to this problem, changed the input mode from stereo to direct and back while playing music and it has not made any difference.
Enabling centre and rear - no difference
Dolby pro logic II - no sound output at all! Same with DTS NEO. If I use tuner or a digital input source these two modes work.
O.K now I think we are getting somewhere. I have swapped the RCA cable to the TV input.
Pro logic plays music with the sub working.
Direct/Stereo plays music with the sub! :banana:
The volume seems off though. I have to max the SW channel to +12db and have the amp volume turned up 3/4 before I can notice the sub. This is at low volume.
I have to go to work now, I will continue testing this evening.
A couple of questions have popped into my head while working.
1. the sub has left and right line inputs neither labelled as a mono input. Is there any advantage/disadvantage/point in using a y split subwoofer cable so I can plug into both inputs.
2. The crossover on the amp is set at 80hz. If i turn the crossover on the sub past 80hz I get more bass response. Why/how does this occur?
You should only have one crossover running. If you can turn one off than do so, if not set one at the highest setting and use the other to control the cutoff frequency.
without researching or knowing your receiver, I see two possibilities:
1) there's a specific setting for two channel analog sources that needs to be set (I know this is the case for my 3310ci)
2) your specific receiver may not be able to output to the sub from an analog source as all the bass management is done typically in the digital domain and unless it can convert the analog audio to digital to process and then back to analog for the pre-outs it just won't do it.
