O.K now I think we are getting somewhere. I have swapped the RCA cable to the TV input.
In the previous connection method using the CD(?) input, were both the analog/RCA connections and the digital connection from the player connected simultaneously to the same input? If so, I wonder if the receiver was getting confused, for lack of better terms, on what to do with the signals.
Many of these receivers can be set up so a source selection, such as CD, can have multiple physical inputs routed to it via the input mapping configuration in the setup. Maybe poke around in setup to see how the physical inputs are mapped to the CD source selection (or whichever it was giving the trouble).
If both RCA and digital were connected at same time, perhaps try disconnecting the digital and retrying with just RCAs connected (to the input that was giving trouble before).
A couple of questions have popped into my head while working.
1. the sub has left and right line inputs neither labelled as a mono input. Is there any advantage/disadvantage/point in using a y split subwoofer cable so I can plug into both inputs.
2. The crossover on the amp is set at 80hz. If i turn the crossover on the sub past 80hz I get more bass response. Why/how does this occur?
1. In some cases feeding both inputs from a Y increases the gain but it depends on the specifics of how the input of the sub is designed. In the case of one of my subs, feeding with a Y gives me 4dB more gain than just single fed. In theory it could be up to 6dB because the two feeds. Doesn't make the sub more powerful (a 100w sub is still a 100w sub, unless you don't have enough gain to drive it to full power) but it may allow you to reduce the SW level setting in the receiver by some amount and still get the same volume. I don't like to run any of my levels at the top or bottom of the range. I try to stay within +/-6dB of the midpoint/0dB just as a matter of personal preference not to run settings toward their limits.
Also, if the sub has auto power on, some report the auto on is more reliable and comes on sooner with the Y feed.
2. Others have covered it, but if using the bass management in the receiver (as you are) set the low pass filter on the sub as high as it can go...120Hz, 150Hz, whatever, at the highest (or turn it off altogether if you can).
