If you’re serious about that particular subwoofer, you won’t have to assume anything. I suggest that you locate and download the SVS subwoofer control app to your phone. I run two SVS SB-4000 subs, and find the app to be highly comprehensive. It allows all of the various parameters to be adjusted from your listening position, which greatly facilitates getting everything dialed in to your satisfaction.I have a Sony STR-HD590 and plan on hooking up a new SVS SB2000 Pro subwoofer. The Sony documentation says very little about the "subwoofer out" connectors in the back of the unit. This is the 1st time hooking up a powered subwoofer. Should I just assume the sub out connector has a low pass filter?
