Suggestions Please
Restored Sanusi AU-7900 Amp,Yamaha PX2 tt with Yamaha MC-1X cart. Stepup? Fine use?
  • Cartridge mv to low
  • Yes u need stepup
  • Will work fine
Results are only viewable after voting.
Curtis Reedy
Allrighty Form, Fully restored Sanusi Au -7900& Yamaha PX2 with Yamaha MC-1X cartridge Does this need the "DO-DAD" To make this sound awesome. You'll know what I'm talking about. Input is appreciated.
You would need either: 1. a step-up amp between the turntable and the phono input of the AU-7900, or 2. a phono amp with low-output moving coil capability, between the turntable and a line input on the AU-7900 (AUX, TAPE IN, etc)..
I got it LOMC cart.
You need a SUT or an MC phono stage.
I don't actually know for sure but think 7900 only has MM phono stage.
IMO, investing in an SUT makes good sense for a vinyl lover. A 1:10 would work, but 1:20 would be better - for this cartridge. An SUT with both is a handy thing to have. Good MC stages are harder to do than good MM stages, which are hard enough.
You have a Low Output Moving Coil (LOMC) Yamaha Cartridge, and your Sansui amp has a Moving Magnet (MM) phono input, which requires a cartridge with higher output, Therefore either a Moving Coil phono Stage or a Step-Up Transformer (SUT) is required for this cartridge to work with that amp.
Thanks
