Rockmore
Can you please summarize by board the parts that you have replaced.
I know you unsoldered the boards this is a concern for me one wrong wire or bad solder joint and who knows.
Lets start over
What are the symptoms?
Does volume effect the sound is the noise always present in tape phone tuner both channels?
If you want to get this fixed you need to provide the info we need to help you.
You may be in over your head on this one I am sure it is something simple but
it is very hard to fix over the internet.
BTW I have an SX-424 that works and is collecting dust
Go through this thread Goat- I think I've already stated what I've done, and used the exact recommended parts. Already have given you all the info you needed- go through the thread.
A brief summary again is:
-Receiver worked just fine (just old and tired) to start with.
-Replaced the caps on all the boards except the tuner.
-Replaced the sd313 transistor, the 2 zener diodes, and 2 resistors on the PS board.
-Replaced the transistors, caps, and 4 wattage resistors on the amp board.
-Replaced the two smaller and one huge block cap on the chassis.
-All the voltages seem to be in range from you guys and are as stated before.
The two boards I cut the wires on and re-soldered are just on the PS and amp boards. Had them all clearly marked, and have gone back through them 3 times. They are all back exactly to the same posts on each board correctly, including to the 3 block chassis caps. Have traced all the wires many times over to ensure each ends are still correctly connected and soldered solidly.
Only thing I havent done is replaced the all of the 2383's and 1013's for the SECOND time... Just the 992's like you Goat kept saying multiple times.
What are the symptoms (again)? See post #73 and and previous.
"...Does volume effect the sound is the noise always present in tape phone tuner both channels?...":
-See post #73. It's not noise. Turning the unit on, there is slight sound out to the speakers with the volume all the way
down. Barely turning the volume up it is very loud and distorted. Doesnt matter what input source (tuner, tape, etc.). Yes, it's both channels. As if the amp is running without a volume control and very tinnie loud raw and distorted. All the pots work just fine- balance, trble, bass, volume.
