Marathon session today ended with a working left channel and the immense relief of a perfectly functioning preamp. Today was new bulk caps, new soft start relay, recap tuner and phono boards, re-replace a couple caps too tall for the amp bd, new micas all around and finally start reassembling.
The only bad parts I have found so far are the leaking bulk baps and the Spkr A lamp, so before it was dropped it may have worked fine.
Still need to paint the inside rear cover and finish reassembly. Tuner is BAD, needs IF adjustment, and the assembled channel is idling at only 10mA, or 10mV rather.
