Thanks for the reply. I finally got this issue fixed today. Thank God...
It turns out that this little Q22 circuit is a total mess in the Pioneer documentation as well
as on a LOT of old threads here... The schematic and the board layout diagram don't agree
on this circuit where Q22 is concerned.
Also the Silkscreen on the board itself shows the Emitter arrow pointing to the wrong side of Q22.
If someone replaced the original component (2SA904A) with the KSA992 or KSA1013, didn't know that the pinout had switched between the components, and just put it in "incorrectly" according to the E indicator arrow on the board they would be golden.
I guess in this case ignorance IS bliss after all.
If you know that the replacement component is the opposite of the original and then followed the E arrow on the silk screen when you installed it then
you would have some serious problems. Which is exactly what I was just fighting for 2 weeks.
Fortunately merlinski had straightened out this issue here in Post #55.
https://audiokarma.org/forums/index...-voltages-at-stks.944917/page-3#post-14458814
Robert Amour's Photo in Post #57 is the only picture that I would trust if you have this same issue and want to
get your negative voltages corrected.
Thanks again to merlynski, RIP, and Robert Amour for the clear and concise information clearing this up for me.
Scheid.
