Uncle Bambi
Funky Tut
Thanks so much for the quick, detailed response.
There is one local supply house about 10 miles from here, so I'll check there for the cap. I was there about 2-3 weeks ago, and seem to remember a lot of NTE packaging.
unfortunately, that is a vulnerable cap, and a low noise to boot. eventually it will need to be changed out. and we can't go with a 25v cap. So order up a poly film 0.47 at 50v on some other order in the future...
2.2 uf will leave you with a lot of mic rumble coming through... the ukl part of the spec would be a match and the 50v part of the spec would be a match..
lamps:
http://www.dgwojo.com/index.php?p=1_2_Products
http://www.vintage-electronics.cc/vlamp.html
they are "fuse lamps" , and the stereo lamp is 8v 50ma and 4mm or so...
