<snip>
I hope Mark comes by and adds his thoughts unless you have a 13v Zener you are on hold for parts.
It IS the -13v, but NOT what you expect.
At this point I am laying odds that it is the PHONO/equalizer amp!!!
here's why:
power supply pin 9 -13v
goes to:
1. Power amp board pin 12, into a 20k resistor as part of the offset adjust voltage reference circuit. So if this resistor is shorted to ground, only a small amount of current will flow.
2. Protection board pin 2
2.a. into a 5.6k resistor biasing the lower half of the DC detector circuit. So if this resistor is shorted to ground, only a small amount of current will flow.
2.b. into a 47k resistor biasing q6 off for the on/off circuit. So if this resistor is shorted to ground, only a small amount of current will flow.
3. Phono / equalizer amp board pin 2.
3.a. into a pair of 6.8k ohm resistors for second stage bias. again, low current
3.b. DIRECTLY into a 220uf 16v capacitor - Nothing in the way of large currents flowing. - this MIGHT be shorting/leaking and pulling too much current.... BUT we have a BETTER suspect..
3.c. Q5 and Q6 DIRECTLY!! Nothing in the way of large currents flowing here .... While they themselves are blameless, the input transistors are 2sa725's and they are DIRECTLY coupled to Q5 & Q6. Nothing in the way of large currents flowing.
and WHAT do we know about 2sa725's??? They get noisy and short out...
so... got some EXTRA ksa992's??? put them into Q1 and Q2 of the phono amp board. Later or if you have them, put in ksc1845's into q3, q4, q5, q6 to get a real improvement in the phono amp, along with the caps.
