Uncle Bambi
Funky Tut
John:
Yep. Use the separate preamp, and connect it to the MAIN IN jacks. This takes and makes the 838 an amp only. Everything else is disconnected from the amp. All your sources would be connected to the separate preamp. If the noise continues in this variation, then the problem is in the amp.
OK - did this. I connected the MAIN OUT on the pre-amp to the POWER IN of the receiver.
I did not get any radio signal through the speaker (no tuner or other input device connected), but I did get light "white noise". After about the same amount of time as before, I heard crackling, popping, then silence when the 838 switched off.
Amplifier issue, no?
I'm trying to scrounge an amplifier to perform the reverse test, but I'm thinking it might not be necessary?
Just for fun, I measured a couple of pins on the protection circuit - red lead on pin, black on chassis ground. did I mis-read the schematic or not measure pin 12 properly, or is this a big, fat clue?:
On the Protection Circuit PCB:
Pin 01 +36.2-----s/b +35
Pin 12 8Vac-----s/b 75Vac
