Ok - I've dumped it into an Excel spreadsheet, and boiled it down to a BOM list.
Mark/forum moderators - do you wish a copy for archival purposes? If so, PM me and I'll email you a copy. Also - is there a "build-sheet" repository on the forum? Would it be worthwhile to bank parts lists by receiver models, in order to help the newbies like me?
Here's the order of battle I envision. First, I replace the transistors and re-cap the power amplifier board to see if we've killed the problem and stabilized the receiver. Now - once that is accomplished, do I check/do voltage adjustments, or do I continue to re-cap board by board? Is there a preferred order to the process?
Just a note on how I replace components. I do one component at a time.
For caps I look at the board to see if the cap markings match the board for polarity.
If the cap does not match the board put the new cap in like the old.
For transistors.
I get the data sheets for the new transistors so I know lead configuration.
I then look at the schematic and board to check verify current transistors lead configuration.
I verify new transistors by doing a transistor test. I have a transistor tester so its easy for me.
This test does two things it test the transistor and makes sure you have the lead configuration correct.
Steps to take
Recap and replace transistors on the power amp board.
Turn volume control all the way down
Hook unit up to DBT verify If the unit comes up OK that means the bulb starts bright then goes dim.
Check DC offset note results you can adjust them a bit to see if you can get them to spec but you will be readjusting later.
Adjust Bias pots verify that Bias can be adjusted watch for no big jumps while adjusting pots.
Turn Bias pots back to set Bias to minimum this must be set without DBT
Turn unit off.
If all this looks good you can bring the unit back up without the DBT and do set DC offset and Bias.
I would recommend you these
565-3782-60-2
565-3782-60-0
Now to complete the recap I do one board at a time and check operation.
Always use DBT when powering up after doing any work.
I would do the rest in this order
Power supply
Protection
These can be done in any order and sometimes you need to move a board to get to another and I may to both at one time
Control Amp
Equalizer Amp (phono)
Mic Amp
This is how I do it.
