SX-838 troubleshooting assistance please
If they are identical except for packaging it doesn't matter too much.
Sometimes when looking for small lytics, and you can't find the exact match, try looking for a poly of the same value and voltage. MTF Likes stacked poly's for anything less than I think 4uf if he can fit them in.
Note that in the early 70's the value system that the manufacturers used changed to the present numbering system. It used to be whole numbers and .5 decimals. so changing overto the new system if you had a 20uf/15V you could look for a 22uf/16V, 22uf/20V or even go as high as 27uf/16V or 27uf/20V.
Most of the time it's recommended that you DO NOT go DOWN in value. With a 20% variance in capacitance in most current capacitors, you CAN go down in some cases. Say you have a 50uf/25V and need to replace it. 20% of 50uf is 10uf. so theoretically you can go DOWN to a 47uf (3%) or up to a 56uf(11%).
the following is as I understand it and is NOT intended to be "GOSPEL". More knowledgeable persons can and will correct this if it is inaccurate.
The voltage is the max working voltage the cap can safely handle. So a 20V can be safely increased to a 30 or 35v so there is some working voltage headroom. Surge voltage rating is more often than not 20-40% higher than working voltages. These occur on startup. So increasing the values on caps has it's rewards in a sense. You get a slightly increased working capacitance and at the same time the parts aren't being stressed at their limits.
Larry
OK - I'm good with the fishing concept. I'll go do it.
Here's the thing, at first blush, when I'm trying to use the mouser search engine for the two cssa caps in question - I don't find any UKL's or film caps that match up.....
For example, c1 1 25 cssa. By definition (assuming I've absorbed your information correctly), I need either a UKL or film cap for a replacement. When I use the search string "1uf 25v" "in stock", and "capacitor", it boils down to 3 leaded electrolytic capacitors (none of which are Nichicon UKL’s), and 2 film caps, both of which are .1uf - not 1uf.
Is the solution then to up the voltage rating to 50v? If so, I come across this:667-ECQ-V1H105JL5.
Similarly, for c3 0.47 25 cssa, I find no suitable caps when searching with ".47uf 25v". But, I do for ".47uf 50v":
647-UKL1HR47KDDANA (electrolytic)
And four likely choices for film:
667-ECQ-V1H474JL3
667-ECQ-V1H474JL
667-ECQ-V1H474JLW
667-ECQ-V1H474JL5
But - when I do a "compare", they show identical specs, except for "packaging". So - Which one of the four to choose? Dunno....time to go fishing.
As an aside, I assembled and tested my Dim Bulb tester today. Works great.
On searching for caps on Mouser I do it a bit differently
I select the product of caps and then the appropriate sub category
in this case Film Capacitors and then Polyester Film
For Stacked Film caps it is OK to use a higher voltage than you might in a electrolytic. Size is the most important thing.
Now I select stocked then I choose my cap value 1uf and then I pick the voltage I need 25v in this case no matches so I use the CTRL key and up
the voltages until I get a match when I got to 50v 10 matches where available.
I like the Panasonics so this is what I picked
awh-031 c1 1 25 cssa
667-ECQ-V1H105JL3
awh-031 c2 1 25 cssa
667-ECQ-V1H105JL3
Now I reset the cap value and pick .47uf
and got 5 matches and I picked this
awh-031 c3 0.47 25 cssa
667-ECQ-V1H474JL3
awh-031 c4 0.47 25 cssa
667-ECQ-V1H474JL3
In a nut shell cssa csza and ceanl use either film caps or a low leakage cap
film 1uf and smaller
To find a Nichicon low leakage cap UKL do this pick
capacitors
aluminum Electrolytics capacitors leaded
click stocked
select Nichicon
Select 4.7uf
In the product list pick low leakage
7 are found
click apply filters
First one in the List
awg-029 c15 4.7 25 ceanl
647-UKL1E4R7KDDANA
awg-029 c16 4.7 25 ceanl
647-UKL1E4R7KDDANA
Change cap value to 10uf 25v
awg-029 c29 10 25 csza
awg-029 c30 10 25 csza
awg-029 c31 10 25 csza
awg-029 c32 10 25 csza
647-UKL1E100KDDANA
Change cap value to 2.2uf
Says No matches found So up the voltage 35v none 50 volts hits go with it
Apply filter and you get
awg-029 c39 2.2 25 csza
647-UKL1H2R2KDDANA
awg-029 c40 2.2 25 csza
647-UKL1H2R2KDDANA
So if you complete the parts list Mark sent you I can help if you get stuck and review it if you like.
Here is the parts list Mark gave you looks like the phono amp was done check
if the parts are in stock and complete the rest and post
Mark asked for transistors and diodes to be added for protection and ps I
will get this info and add to this list
phono amp
awf-011 c1 1 25 cssa 1 50 667-ECQ-V1H105JL5
awf-011 c2 1 25 cssa 1 50 667-ECQ-V1H105JL5
awf-011 c7 330 6 cea 330 10 647-UPW1A331MPD
awf-011 c8 330 6 cea 330 10 647-UPW1A331MPD
awf-011 c11 3.3 25 ceanl 3.3 50 647-UKL1H3R3KDDANA
awf-011 c12 3.3 25 ceanl 3.3 50 647-UKL1H3R3KDDANA
awf-011 c17 100 25 cea 100 25 647-UPW1V101MPD
awf-011 c18 220 16 cea 100 25 647-UPW1E221MPD
awf-011 Q1 2sa725 0 0 0 0 512-KSA992FBU
awf-011 Q2 2sa725 0 0 0 0 512-KSA992FBU
awf-011 Q3 2sc1313 0 0 0 0 512-KSC1845EBU
awf-011 Q4 2sc1313 0 0 0 0 512-KSC1845EBU
awf-011 Q5 2sc1313 0 0 0 0 512-KSC1845EBU
awf-011 Q6 2sc1313 0 0 0 0 512-KSC1845EBU
mic amp
awm-064 c2 220 35 cea
awm-064 c3 0.47 16 cssa
awm-064 c6 220 6 cea
awm-064 c7 0.47 16 ceanl
control amp
awg-029 c3 47 35 cea
awg-029 c4 47 35 cea
awg-029 c7 10 25 csza
awg-029 c8 10 25 csza
awg-029 c13 100 10 cea
awg-029 c14 100 10 cea
awg-029 c35 100 6 cea
awg-029 c36 100 6 cea
awg-029 c37 47 35 cea
awg-029 c38 47 35 cea
power amp
awh-031 c7 33 16 cea
awh-031 c8 33 16 cea
awh-031 c11 330 10 cea
awh-031 c12 330 10 cea
awh-031 c13 100 50 cea
awh-031 c14 100 50 cea
protection
awm-025 c1 0.22 10 cssa
awm-025 c2 0.22 10 cssa
awm-025 c3 330 6 cea
awm-025 c4 330 6 cea
awm-025 c5 4.7 25 cea
awm-025 c6 100 16 cea
power supply
awr-055 c8 470 80 ach-038
awr-055 c9 470 80 ach-038
awr-055 c10 100 50 cea
awr-055 c11 100 50 cea
awr-055 c12 220 16 cea
awr-055 c13 2200 10 cea
awr-055 c14 220 50 cea
awr-055 c15 470 16 cea
OR
power supply
awr-064 c8 470 80 ach-038
awr-064 c9 470 80 ach-038
awr-064 c10 100 50 cea
awr-064 c11 100 50 cea
awr-064 c12 220 16 cea
awr-064 c13 2200 10 cea
awr-064 c14 220 50 cea
awr-064 c15 470 16 cea
Goat: a quick note:
for general caps I type in 100uf UPW and it gives me a check list of voltages to select or I can cause them all to be sorted by voltage.. instant overview of what they carry for that line, and what's in stock. and when I sort the target list in the spreadsheet by (cea/ceanl,cssa etc first) capacitance and voltage, you can see how I get the speed in selecting caps.....
got a weird cap value? just use UPW and it will TELL you what values it has in a check list. Pick the closest.
do the same for low leakage, 2.2uf UKL, and so forth
non polarized same thing. i just don't remember for sure: ues, uvp,uep ....
stacked film caps are ECQ and DSF...
Ok - thanks for all of the searching and spec help - I've fleshed out the capacitor parts list and pasted it below for review. Here's what I have - does it look good to go?:
equalizer amp (Mark did this section)
mic amp
awm-064 c2 220 35 cea 647-UPW1V221MPD
awm-064 c3 0.47 16 cssa 667-ECQ-V1H474JL3
awm-064 c6 220 6 cea 647-UPW0J221MED
awm-064 c7 0.47 16 ceanl 667-ECQ-V1H474JL3
control amp
awg-029 c3 47 35 cea 647-UPW1V470MED1TD
awg-029 c4 47 35 cea 647-UPW1V470MED1TD
awg-029 c7 10 25 csza 647-UKL1E100KDDANA
awg-029 c8 10 25 csza 647-UKL1E100KDDANA
awg-029 c13 100 10 cea 647-UPW1A331MPD
awg-029 c14 100 10 cea 647-UPW1A331MPD
awg-029 c15 4.7 25 ceanl 647-UKL1E4R7KDDANA
awg-029 c16 4.7 25 ceanl 647-UKL1E4R7KDDANA
awg-029 c29 10 25 csza 647-UKL1E100KDDANA
awg-029 c30 10 25 csza 647-UKL1E100KDDANA
awg-029 c31 10 25 csza 647-UKL1E100KDDANA
awg-029 c32 10 25 csza 647-UKL1E100KDDANA
awg-029 c35 100 6 cea 647-UPW0J101MDD
awg-029 c36 100 6 cea 647-UPW0J101MDD
awg-029 c37 47 35 cea 647-UPW1V470MED1TD
awg-029 c38 47 35 cea 647-UPW1V470MED1TD
awg-029 c39 2.2 25 csza 647-UKL1H2R2KDDANA
awg-029 c40 2.2 25 csza 647-UKL1H2R2KDDANA
power amp
awh-031 c1 1 25 cssa 010m 25 667-ECQ-V1H105JL3
awh-031 c2 1 25 cssa 010m 25 667-ECQ-V1H105JL3
awh-031 c3 0.47 25 cssa r47m 25 667-ECQ-V1H474JL3
awh-031 c4 0.47 25 cssa r47m 25 667-ECQ-V1H474JL3
awh-031 c7 33 16 cea 330p 16 647-UPW1C330MDD
awh-031 c8 33 16 cea 330p 16 647-UPW1C330MDD
awh-031 c11 330 10 cea 331p 10 647-UPW1A331MPD
awh-031 c12 330 10 cea 331p 10 647-UPW1A331MPD
awh-031 c13 100 50 cea 101p 50 647-UPW1H101MPD
awh-031 c14 100 50 cea 101p 50 647-UPW1H101MPD
protection
awm-025 c1 0.22 10 cssa 667-ECQ-V1H474JL3
awm-025 c2 0.22 10 cssa 667-ECQ-V1H474JL3
awm-025 c3 330 6 cea 647-UPW1A331MPD
awm-025 c4 330 6 cea 647-UPW1A331MPD
awm-025 c5 4.7 25 cea 647-UKL1E4R7KDDANA
awm-025 c6 100 16 cea 647-UKL1C101KPDANA
power supply
awr-055 c8 470 80 ach-038 647-UPW2A471MHD
awr-055 c9 470 80 ach-038 647-UPW2A471MHD
awr-055 c10 100 50 cea 647-UKL1H101KPD
awr-055 c11 100 50 cea 647-UKL1H101KPD
awr-055 c12 220 16 cea 647-UPW1E221MPD
awr-055 c13 2200 10 cea 647-UKL1A222KHD
awr-055 c14 220 50 cea 647-UKL1H221KHD
awr-055 c15 470 16 cea 647-UKL1C471KPD
Ok - thanks for all of the searching and spec help - I'll keep fleshing out the parts list and post here for review. Since, as Goat67 suggested, it would be prudent to only disturb the power amp board once, can someone vet this portion so I can order them and do it while I do the transistors? Here's what I have - does it look good to go?:
power amp
awh-031 c1 1 25 cssa 010m 25 667-ECQ-V1H105JL3 1uf 50v <<<<<<<<
awh-031 c3 0.47 25 cssa r47m 25 667-ECQ-V1H474JL3 0.47uf 50v <<<<<<<
awh-031 c7 33 16 cea 330p 16 647-UPW1C330MDD 33uf 16v
awh-031 c11 330 10 cea 331p 10 647-UPW1A331MPD 330uf 10v
awh-031 c13 100 50 cea 101p 50 647-UPW1H101MPD 100uf 50v
notice I did one thing, that makes it far quicker to check:
example:
I included the revised values of the caps as numbers. not codes, that way any misunderstandings of the codes by either side get ironed out.
Just so you understand the effort, I just cut and pasted every cap type into mouser.com and looked at the data page for that cap, thus discovering that the uf values were correct, and that a few voltage substitutions had been done. Had the list been longer I would have just passed on by...
power amp
I would recommend that you get a full parts list together and only order once to save shipping costs.
example:
Ok - will revise the list as you need it, and re-post.
With my suggestions list looks good
Mark do you have time to post the transistors / diodes for the PS an Protection Circuit to make this complete?
Fly back diode 512-1N4004
Here is what I found in other posts I have not checked stock...
Protection
q1 q2 2sc869
512-KSC2310YBU to-92 ecb 150v .05a .8w 100mhz 40-240hfe $0.11 ea
Q3 & Q4 2sc945 dc detect differential amp circuit
512-KSC945CLTA to-92 eCb 50v .15a .25w 300mhz 40-700hfe $0.05 ea
OR
512-KSC945LBU to-92 eBc 50v .15a .25w 300mhz 40-700hfe $0.05 ea
Q5 2sa733 inverts / shifts signal levels
512-KSA733CLTA to-92 eCb 50v .15a .25w 180mhz 40-700hfe $0.05 ea
OR
512-KSA733LBU to-92 eBc 50v .15a .25w 180mhz 40-700hfe $0.05 ea
Q6 2sc945
512-KSD1616ALTA
Q7 2sc1384
512-KSC2383YBU to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.17
Power Supply
Q1, Q2 2SD313-E 2SD313P E or D
512-KSC2073TU npn to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.54
Q3
OR
mic amp
control amp
power amp
protection
awm-025 c5 4.7 25 cea 647-UKL1E4R7KDDANA 647-UPW1E4R7MDD
awm-025 c6 100 16 cea 647-UKL1C101KPDANA 647-UPW1E101MED
power supply
awr-055 c10 100 50 cea 647-UKL1H101KPD 647-UPW1J101MPD
awr-055 c11 100 50 cea 647-UKL1H101KPD 647-UPW1J101MPD
awr-055 c13 2200 10 cea 647-UKL1A222KHD 647-UPW1C222MHD
awr-055 c14 220 50 cea 647-UKL1H221KHD 647-UPW1J221MPD6
awr-055 c15 470 16 cea 647-UKL1C471KPD 647-UPW1E471MPD6
Ones marked in bold is what I would recommend the UPWs are a better cap in protection and power supply circuits.
OK - I'll make the substitutions. I only booted 7? Maybe I shouldn't.... but I feel pretty good about that.
Question #1:
The guideline posted previously specified that cea caps should be of the UKL variety. That's why I chose the one's I did. This is an excepoion to that rule, for the reason you cite?
Question #2:
I understand why electrolytic caps need to be replaced, and I understand why I'm replacing the problem transistors that Mark flagged for me. But why am I changing the other transistors and the diodes? Do they go unstable with age, or did they get superseded by superior components?
Just trying to clarify, as I'm making a reference document that I can use in the future. I don't to be a bigger pest than necessary. :)
Once word got around my circle of acquaintances that I'm attempting this, gear has started falling from the sky into my lap.......
Question #1:
Question #2:
regarding capacitors:
I have a rally to prepare for and help at tonight, so that list will be worked on tomorrow.
Cap rules of thumb (nichicon)
I use upw, uhe for general caps including signal coupling in that order depending upon stock "cea"
I use ues, uep & uvp in that order for bipolar depending on stock
I use ukl for low leakage caps (in sensitive areas they reduce the noise floor)"ceanl", "cssa", "csza"
0.1uf to 2 uf I use stacked film where they fit: DFS and ECQ
solid aluminum and tantalum caps get stacked film when possible, or ukl's otherwise. "cssa" "csza"
c?B means it's an axial cap = one lead on each end
c?a = radial = both leads on one end
searching at mouser:
easy..... need a 100uf cap? search on: 100uf UPW
then find your voltage and if stocked / in stock and possibly a size choice. go UP in voltage if your voltage is not available.
voila....
sub uhe, ukl, dfs, ecq etc for upw for the different type...
just because a transistor is listed doesn't mean it needs to be changed. theentire list is there for folks who are having problems with that circuit.
flyback diode 1n4004
q6 gets a ksd1616, technical reason: "safe operating area"...
look at the current 939 thread re: protection...
Ahh.... I see what I did - thanks. I've been fighting a nasty head cold, and I guess my eyes got lazy at the bottom of the list. Thanks again.
OK - makes sense. I hate to appear any thicker than I already do, but aside from the problem ones you specified way back for the AWH-031 board, are there any additional that I need to include in my final BOM?
Going to the 939 thread now........
If I was ordering parts I would get the transistors and diodes for the PS and Protection boards.
The cost is minimal and even if you do not need them now you may in the future.
If what you say is true about other units coming your way they may be used to repair something else.
Exactly what I was thinking, as I read the narrative on the 939 protection circuit problems in the thread Mark referenced. Seems like cheap insurance just in case.
Location - power supply?
Another question.....
On the equalizer amp, you specified:
On the power amp, I came up with:
awh-031 c1 1 25 cssa 1 25 667-ECQ-V1H105JL3
awh-031 c2 1 25 cssa 1 25 667-ECQ-V1H105JL3
Can I assume I can I make all of them the same to simplify ordering?
Only difference is the 667-ECQ-V1H105JL3 are ammo packed which means that they
will come with a strip of paper on the leads so they can be loaded
into an insertion machine kind of a hassle to get it off.
Magic word: HEAT....
Of course it helps if one keeps a hot air gun (paint stripper) hanging next to the bench, always plugged in and ready to go .
The glue residue will affect soldering a but, but it's on the far end of the lead - which is usually unused.
and yes, if others are tossing equipment at you, extra transistors are useful, these are the ones I keep around in quantity:
ksa992/ksd1845 audio and general
ksb1116/ksd1616 instead of a733/c945, more current drive
ksc2310 150v
ksa1013/ksa2383 up to 1 amp
ksa1220/ksc2690 1 amp to-126
ksa1381/ksc3503 0.1 ap to-126
ksa940/ksc2073 1.5amp to-220
1n4004 1 amp power rectifier diodes
1n4148 0.2 amp 100v signal diodes
Years ago I would have killed for a list like this....
there have been others on this list, that have been dropped primarily because one of the complementary pair has been obsoleted...
Ok - lots and lots of great information. Overwhelming, really.
Goat67 has vetted the cap list, and I've made his suggested changes and added all the transistors and the two diodes mentioned.
Am I ready to distill it into a BOM and make the order?
I say you are ready lets hope we got it all covered.
