merlynski
Curmudgeon Electronicist
Things that make you go HMMM. Is R23 on the AWR-101 10Ω? Have you cleaned the FU6 fuse clips (deoxit) and put in a new fuse? I am scratching for answers now . . .
Power off. Pull the fuse out.
Measure the resistance of the winding, it should be just a fraction of an ohm, if your meter can go that low.
Measure the resistance of the lamp circuit to ground.
Power on.
Measure the output voltage of the winding with the fuse out, see what the unloaded acv is.
Power on.
