no matched pairs. with an amp with an output capacitor it just plain AIN'T in the equations, literally.
beefier components = longer (cooler) life (loafing rather than straining), NOT more power - power's determined by the design, starting at the power supply. where the "limit" is clipping - that's when the tops of the waveforms are chopped off because more voltage (at that current... i.e. POWER) is NOT available.
NOT diminishing return, it just plain FREEZES...
wanna know the difference between a high buck pure class A amplifier and these A-B's? "idle" current. Lets say the class A can deliver 3 amps of current out... that means the current through the class A outputs at idle is 3 amps.... and they have to dissipate any difference between the power going to the speaker and the "idle" current power as pure heat.
I think I got that...power output is just what the system design will do before clipping. It is what it is and when you get it there that's where you want it!....your done!
Having the beefier components just provides good stability and cooler operation.
The crossover distortion is that transition point where they're switching and when everything is set correctly there is little or no switching offset??
If there is excessive offset (crossover distortion) will that manifest itself as audio distortion??
And again this is a set it and that's it. It will be as good as you can get it...right?
Is that something you can watch on a scope or fine tune?
I was looking at the schematic again and so the 50ohm trimpot and STV-3 are there to set the 2 bases of that NPN/PNP pair (2SC497/2SA497) and as the temperature starts to go up the STV-3 changes to allow a little more current???....or is it allowing less current?
And the 30k (50K now) trimpot adjusts the voltage and therefore current at those output transistors to be balanced equally??
I notice you want that center point to be 28V or half the supply voltage.
And the push-pull (Class A-B) is those two providing the + region of the waveform (push?) and the other is providing the - (pull?)
I had read that Class A is "always on" so that's why it is less attractive in terms of efficiency?
But they are more linear and you don't have that crossover distortion problem switching on and off.....correct?
Sort of like switching power supplies and linear ones....we are being driven by "efficiency" rather than quality and linearity.
I think this concept is becoming ever more prevalent today...more than we realize...
I like effeiciency but what we need is good consistent cheap power..!!
