dnpainting
Thank you Mark for overlooking those proceedures and djmtascam for writing and drawing up the new doc. I will have to open up the 990 I gave to a friend to check and re-adjust.:thmbsp:
looks good on first pass.
Thank you Mark for overlooking those procedures and djmtascam for writing and drawing up the new doc. I will have to open up the 990 I gave to a friend to check and re-adjust.:thmbsp:
I'm curious dnpainting...was there something in my steps that was different..and what do you think is misaligned or incorrect on your unit?
I would make sure my instructions are fully QA'd by Mark!
I just don't recall using TP1 and TP2. It was a while back and Marc was unavailable at the time. I am sure that everything on the one my friend has is fine but being a newbie at these repairs, I just want to make sure I crossed my T's and dotted my I's is all. Also, I am going to go ahead with changing out the 4 pots in there.
they brought out test points in later models. they were learning too back then. Tube equipment mindsets adjusting...
NOT bad, just different....
just double checking - mica's between the output transistors and the heat sinks? The sink is (probably) isolated on the board like that so a ground check might fool you.
What I do is to get through the anodizing at two points for a zero ohm reference, then check to each collector etc... winding up with retesting zero ohms while trying throughout NOT to loose contact with the heatsink on my stationary reference point.
looks good
when on dbt set the center point voltage of one collector at 1/2 the voltage of the other collector. Then TRIAL set the idle current to tease out any faults, then back to zero - one channel at a time.
then if successful, go straight to the power line, recheck the center point voltage and do the idle current for real.
Yes new mica washers and grease between the transistors and heatsink.
I will double check the collectors though!
When you say set the center point voltage to half....do you mean adjust VR3/VR4 to 10mV first?
I'm confused by this..
So just to make sure I'm clear...
Sounds good!
Hope it results in good sounds!!
the positive or negative part of the waveform will be clipped prematurely. You won't get "full swing" (or power) out of the amplifier before it starts to distort.
It (990) is rated at 35w, which means a +/- 17 volt signal sent to the speakers, and you loose a few volts at the transistors from the theoretical maximum of the supply voltage.
