andreidaniel
Member
Hi everybody!
I tried to make a radio with TA2003P. It works very nice on FM, nothing to say wrong about it. The sound is clear. The only problem could be the ceramic filter (BPF88-108) for the antena, it takes too much of the active signal, but if is replaced by a capacitor of around 15pF or by an LC circuit in "T" the problem is easyly solved.
The big problem is for both TA2003P and its equivalent CD2003GP is that while AM working a good part of the band is occupied by a local or regional powerfull radio transmitter. While is centered, the audition seems to be crowdy and overmodulated, depending on the power of the radio transmitter for that area. I changed the coil oscilator or the capacitor either in series with the variable capacitor or in parallel with it but nothing changed. The only thing I can observe is that while adjusting the red coil for medium waves is that a half of the band is more sensitive or the other one. Does anybody know if there is a small artificial to solve the selectivity on the AM? On a commercial radio I saw two ceramic filters put in series through an 1nF capacitor, but even this solution doesn't work. I also tried to use the IC as an IF stage for AM and taking the signal after the mixer stage fron another radio, but, again the sound is somehow overmodulated and the sensitivity is not so good.
