pari57
Member
Hello guys,
I am working on a Tandberg tuner TPT3001 and I need some help.
When I got the unit it was NOT working at all.
The tuning wheel and the other parts of the tuning system were all stuck.
The tuning wheel tip was completely corroded as well as its copper connection on the PCB. The mechanical part was stuck. Impossible to move.
Other regular problems like dried out and leaking caps were clearly visible as was the corroded battery.
Also the regular problems with the presets not working.
I have replaced all caps for new ELNA SILICA-II, except for the two 1000µF on the Decoder PCB (due to height restrictions) and the ones on the Power PCB.
Also the Battery has been replaced by a new one. I made a new preset switchboard.
I polished the tuning wheel and its PCB contact.
I disassembled the mechanical tuning part with the tuning potentiometer and got the whole part moving again.
On top of that have I implemented the changes that are mentioned in the Tandberg Service notes regarding the units of lower production series. Mine is #00424.
The unit is working fine now including preset station programming.
However it has a somewhat curious failure.
There seems to be is a problem with the bandwidth selector circuit.
When switching the unit “ON” and the bandwidth selector is on “normal” or “narrow” it works fine. That is: it runs fine and the selector can be switched from "narrow" to "normal" to "wide" up and down as one likes and it all works fine. Differences in fine-tuning and station selection are clearly noticed.
But,
When switching the unit on with the selector on “Wide”, the unit works fine at first, but when the selector is switched to “normal” there a disruption.
The 15V power line supply drops to 7,5 V.
When switched back to “wide” or when switched further to "normal" and “narrow” the 15V power line changes to 8,2 V.
Every next change in bandwidth will not change this situation.
Due to the drop in the 15V power line the station selection is “off balanced”.
When the unit is turned "OFF" and after 20/30 seconds is turned "ON" again, it is like a reset.
With the selector switch on “normal” or “narrow” there is NO Problem
With the selector switch on “wide” and switching to narrow, the same problem occurs again.
If anyone has an idea where to find the answer I am grateful.
But,
