Well I'm back with another head scratcher! My friend brought me a tandberg 2080 to try to get restored and up and running for him. I tried to warn him that I'm more familiar with tube stuff and have only done basic recaps on solid state gear but he wouldnt listen!
So we this thing arrived on my bench it would power up but there was no sound from the speakers. After a once over I noticed that the 6v 3w festoon lamp fuse on the regulator board had blown. These are kind of expensive so I advised that we should do a basic recap (saving the more expensive filter caps for last once we get this thing making music) to avoid wasting the lamp fuses. After the recap the fuse is now staying steady dim and I'm getting noise from the speakers but the hum drowns out any music.
I found a troubleshooting thread and that lead me to check the +25v rail and I'm getting around 29v. Is that close enough? I've checked all diodes in circuit and none are reading shorted or open and when I power on with my DBT hooked up the light immediately dims to almost no light so that's a good sign! Also I found if I remove the jumpers and plug a source with volume control direct to the power amp I get clean sound from.both channels. That makes me think something wrong on the preamp board but not positive where to start digging. Oh also the replacement lamp fuses I found are a little smaller than the originals but the do fit. I blew 2 or 3 in the process of getting this thing recapped but they are finally steady.
