If you're talking about the main drive belt as seen from underneath, IIRC all you need to do is loosen the bracket that holds the main capstan flywheel bearing in place and slip the belt out and then slip the new one in.
If you're talking about the belts that spin the magnet beneath the reed switch under the odometer-like tape counter, IIRC there's one or two screws that hold the pulley bracket(s) in place.
If you're talking about the belts that drive the reel hubs, I'm sorry but I have no clue. I had an A-100 for 20+ years and they never failed.
I am taking apart an A-150 right now. It's pretty clean but the main drive belt is a little chewed up and draped over and around in an interesting but entirely ineffectual way. The other belts seem to be in good shape.
Is it worth spending $25 bucks to get a replacement belt? Anybody got a service manual that will show me where a belt is supposed to run?
Kid T, if it looks like it's worth fixing, I'll buy the manual and share it with you.
Mine appears to be in excellent shape. I bought it from the original owner for $14 so I would say yes it seems like its worth fixing. Thank you for the offer on the service manual
