A lot of amps just run the center tap or the negative side of the rectifier to the chassis, then use the chassis for making electrical 'ground' connections throughout the amp. This was pretty common practice in many of the 'console' type amps, as well as many of the 'entry level' offerings. A lot of the 'better' amps isolated the electrical ground from the chassis. If you have no 'chassis' ground, then there will be some kind of 'ground scheme' or 'ground buss' throughout the amp. In tracing where the power supply presents the negative DC ground path, you can begin to follow all the varying connection points throughout the actual construction and 'physical' part of the circuit (as in the actual wires and lugs, etc). This is often 'tricky', as some of them get 'daisy-chained' from point to point, while others are more of a 'star' ground; one central location with ground wires going off in all directions under the chassis. Or, the 'buss' type ground where there is simply a single grounding wire running throughout the amp and all the circuit grounds attach to it. I guess this is just a matter of design choice or manufacturing needs. Sometimes the tail wags the dog, and what engineers and designers say HAS to happen, get's tossed out for what 'CAN' happen as related to assembly potential. Anyway, I've seen commentary on the benefits and detriments of all these different ways to run 'ground' in an amp. I'm pretty sure that from a purely technical standpoint the ground isolated from the chassis, and as distant from the actual 'amplification' section of the circuit is probably the best from a signal purity standpoint. Also probably the most difficult to achieve in construction. Honestly, most of what I've built has used a chassis ground, which admittedly does intermix the electrical DC ground of the amp with the 'signal' ground coming in from the source. As yet this has not caused me any real issues to have to deal with. But, I also have to say that when I see some of the absolutely beautiful jobs of construction some of the people here on AK have done with their amps and the grounding schemes, I'm humbled!! It's like electronic 'art' to me! I wish I had the patience and foresight to build a project at that level. Maybe as I get better at it.
