Dave,
Thanks very much for sharing your experience with the 51-58 transformers made by Mid-West Coil. Based on your experience I can now proceed without sweating the non-Stancor transformer source. I have an oscilloscope and will check for the oscillation at 20Hz that you addressed in your AA-151. (I also have a pair of “genuine Stancor” 51-58 transformers that I will compare). Interesting to note that your AA-151 was fitted with 51-58 output transformers, because the OEM stock was the 51-29 transformer, I believe.
Thanks also for reminding us of the two additions to the original EFB™ circuit, as used in your AS-100 clone. In my case I will use the stock AA-100+power transformer which has a 50Vac tap for a fixed bias supply, like you used in the Fisher 400 EFB mod for example.
