No, color coding in AT styli (where it exists at all) is for the diamond shape. It doesn't in any way identify the cart. Post a photo and I can tell you which series. This page may be helpful.Hi all! I ended up going with the 1700 and am super excited to get her hooked up. Only issue I’m having is I can’t tell what the tracking force should be for the cart that’s on here... The seller had listed it as having an “upgraded AT cartridge of a similar era to the table.” It’s a blue AT cart but doesn’t have a model number on it near the logo on the underside (where it seems to be on newer models.)
Seems like a current model in the same shade of blue is the vm95 with a tracking force of 1.8-2.2 but I don’t know if the color coding was consistent throughout the years, or means anything at all. Is that a rough standard range that should be a good starting point? Or do I need to figure out exactly which cart this is to be safe? Sorry for the noob question, but Google was no help here.
Removing and intalling a cartridge is not difficult, especially with that headshell.
But if forced to guess, I would say that it is an AT10 or 11 elliptical.
If so, 1.5-2.0 grams. You might want to verify alignment. Simple way is to move cart forward or backward until stylus tip is 52mm from rear of washer/gasket on the headshell bayonet.
Or learn how to do it. If he can change batteries in a flashlight, I bet he can do it without too much anxiety. The skill sets are of approximately equal difficulty
Mimimally he could check it, and then decide if it is worth the effort to loosen the screws and adjust it.
Checking alignment requires nothing more than a good metric ruler...and if it's not right, all it takes is a slight loosening of the sled screw so that it can be moved forward or backward, as needed.
I guess the alternative is take it to a service shop and pay them to do it...but if you are going to have a TT, it's probably a good idea to know how to set it up.
That’s why I told him to get an owner’s manual and do it right. I’ve had turntables since the very early 70s. Some were easy to setup and some were not.
Incorrect stylus placement can cause inner groove distortion and improper weight can cause tracking problems and also distortion.
He’s lucky that he has the single screw head shell. That makes it easier to measure stylus forward alignment.[/QUO
Curious...what is different between my advice and what is in the manual?
I hope he saw my link for the JICO. It was the last worthwhile post in this thread.
Based on spark1 I re-adjusted from 2 down to 1.7 and everything has been sounding pretty fantastic.But if forced to guess, I would say that it is an AT10 or 11 elliptical.
Looks like JICO still has the shibata in stock and at a very reasonable price. You will LOVE this...
https://www.jico-stylus.com/product/ats12s/
markshan, appreciate the rec! To clarify what I’m looking at with that link, is that a stylus alone or a stylus and cartridge combo? I ask because in the earlier list of styluses from stereoneedles.com that spark1 linked to, the shibata was a little over $50. Wondering if the prices have just gone up significantly (almost x3) or if that JICO link is for an improved cart over the AT10.
