Technics RS-1500 FF and REW do not stop
Not that old
Hi,
I bought a Technics RS-1500US some time ago and found a few problems.
  • FF and REW do not stop when pressing STOP.
  • The left and right tension arms have different end positions. The left one stops in the top position but the right stops about ½” lower.
  • The left tension switch S19 was erratic.
PLAY works fine and stops when pressing STOP.
I have repaired the S19 tension switch and it now works OK.
FF and REW only be stopped by releasing the tension arms.
I have recapped the entire unit and hoped this would resolve the FF and REW issue, but unfortunately it did not.
I do not understand why the tension arms have different end positions, as the brackets cannot be adjusted as far as I can see.
Thankful for all kinds of advice and help.
You might need to rebuild the brakes? Thin cork clued to the metal band and then some fine adjustments.
(EDIT... for some reason, I can't attach any files or pictures. I'll try again later) If you have the SM and Schematics, you can look it up yourself.
Here is the schematic of the Main Control Board.
  • The FF (S13) and REW (S14) buttons come from the Key Switch board into the connector B (pins 4 & 5) on the Main Control Board (see schematic)
  • The switch closures go through some discrete logic and come out on connector D (pins 4 & 3) (see board layout)
  • When you press either the FF or REW button, the signal on connector B should go from 5v to 0v when you press the button
  • With your DMM, check the voltage on pins 4 and 5 as you press the button down to see if the voltage changes.
  • If it is good, the do the same check on connector D pins 3 and 4 (these may be the opposite logic, 1=H, 0=L)
I have a few questions to help isolate the problem:
  1. If you press the FF button, does it start fast forward?
  2. If you press the REW button, does it start rewind?
  3. If you are in FF and you press REW, does it switch to rewind?
  4. If you are in FF or REW and you press PLAY, does it stop winding and go to PLAY?
The brakes can be adjusted there’s a procedure in the service manual if you spin the reel motor clockwise and anticlockwise do they feel any different? Do this with power off is there any evidence of internal tampering with the machine?
Starting with your questions.
1. FF button starts FF. 2. REW button starts REW. 3. If in FF nothing happens when pressing REW. 4. Pressing PLAY has no effect on FF or REW. 5. If in REW nothing happens when pressing FF. Only releasing the tension arms stops FF and REW.
Then to checking connectors B and D.
Pins 4 & 5 in D hover around 0V whatever I do. Before and after pressing FF or REW. Same goes for B pins 3 & 4.
I am measuring ground to pin, not pin to pin. I am a mecanical guy, unfortunately not an expert in electronics, so I need all the help I can get.
Very glad you looked into my problem.
Thanks for your responses. What kind of test equipment do you have (multimeter, oscilloscope, etc.)?
Can you read a schematic diagram?
  1. On the left is the Key Switch Board containing all of the transport keys
  2. On the right is the Main Control Circuit Board that contains the logic for the transport switch control
  3. I have highlighted the main signal paths for the FF (red), REW (green), and STOP (blue) controls
  4. The top part of the schematic is mainly the logic that reads the tape transport keys (just momentary contact switches) and generates signals to output on connector "D"
  5. In your response to my questions 1 & 2, both the FF and REW switches start the FF and REW motor functions so we know the push switch works and the signal gets through the primary signal path
  6. You said that pressing STOP, PLAY, or other buttons does not stop the FF or REW operation
Could you please double check what you said below? (See the board layout for connector locations.)
  1. "Pins 4 & 5 in D hover around 0V whatever I do" - This should be "Pin 4 and Pin 6 on Connector B."
  2. "Same goes for B pins 3 & 4." - This should be "Pin 4 and Pin 3 on Connector D."
  3. Also, STOP (button should go to Connector B Pin 1.
  4. Since the switches are momentary contact on Connector B, you need to measure the voltage while you hold down the button and when you release the button.
  5. Sorry for the mixup. I think I got it right now.
Hi,
Thank you for the update. I have a Fluke, Millivoltmeter, Signal generator and an Oscilloscope (just learning how to use the latter).
I can read a schematic in a very amateurich way and can follow your marked instructions.
As for the measured values, it is still the same. With PWR ON and tension switches S19/20 activated (arms down), STOP button ON or OFF, pins 4 & 6 on Connector B read 0 V.
The same goes for pins 3 & 4 on Connector D ( 0 volts).
Am I wrong in thinking that pin 2 in connector D should have 5 Volt? It says 5V on the diagram. I only get zero there when I test it.
Looking forward to further info and troubleshooting from you.
Regards
Yes you should get +5V at pin2.
Follow Pin 2 back to the source of the +5V (red dotted line), TR608 collector.
Check the voltage there. Also check the base and emitter voltages. They should be as shown on the schematic and board layout.
PWR = ON
TR608 values: B=0,15 - C= 0,15 - E= 0,15V.
Something is definitely wrong. Can it have anything to do with switch 25-3 on the AC/DC board? Or with the board as such.
I have not touched the external selector switch. This is just a wild guess as I am no expert on wiring diagrams.
OK, thanks. First-off let's check to make sure that the two fuses on the Power Supply board are OK.
  1. Power OFF and unplugged.
  2. Set your DMM to measure Ohms.
  3. Measure the resistance across fuse F2. What do you get?
  4. Next, measure the resistance across fuse F3. What do you get?
It looks like those fuses can be easily removed and replaced.
  1. Just to make sure they are bad, remove one of them and look through the glass. Can you see a burnt, melted wire inside? Do the same for the other.
  2. You can also test them out of the board again with your DMM set to Ohms and a low resistance setting (unless your DMM is auto-ranging).
  3. From the layout/schematic F2 = 1A, F3 = 4A. It should be stamped on the metal end cap.
  4. Replace with new fuses if blown.
I don't know what blew the fuses (there may be other issues), we can try and replace them and see if they blow again. Maybe that will give us a clue.
Check this board and other boards for swollen capacitors or burnt components.
F2 = OL. F3 = OL.
Thera are no glassfuses at F2 and F4. Only metal wires. Never have been as far as I can tell. There is no input voltage on any side of the fuses. Neither at inputs and outputs of diodes D601 and D604. All measurements taken chassis to testpoint and in DC. The PWR. Supply has been recapped with the correct caps and and positioned correctly.
The problem was there before recapping.
If there are no fuses there (as I can see in your photo), how did your DMM measure OL across F2 or F3? When measuring resistance "OL" means there is no resistance or very high resistance?
I could not even get a beep across F2 & F4. After scraping the wires (they seemed to have been prepared with some kind of varnish), I managed to get both beep and 0,2 Ohm resistance over the "fuses". Now I also can measure 36V at F2 and 30V at F3. Before scraping the wires I got 0 volts on both of them.
My measurements had nothing to do with my "wirecleaning".
It seems as if the feed to the Power Supply Board is intermittent. Sometimes I have 30 and 36 volt at F2 & F3, sometimes zero volt.
The first time I measured, the two straight wires (fuses) indicated OL and when checked for voltage they read zero.
Now I get 30 and 36 volts.
TR 608 now reads E=11V, B=10,3V and C=5V, which is normal.
Pins 2,3,4,5 on connection D of the Main Control Board now show 5V.
The STOP button still has no effect in FF & REW though.
I will have to look into the problem with the supply voltage from the transformer.
It can be anything from a bad solder to a loose connection.
I very much appreciate your help in troubleshooting though.
Once you get the 5v stable, we can look into the stop button logic (which is what we started to do). Let me know when you fix the power problem.
