OK, so now I see that I made a mistake on assuming wiring to Connector B.
It looks like the two 6 pin connectors on the Key Switch board are wired not to Connector B, but to the two large white connectors.
The board traces then go to Connector B.
Can you easily get to the two 6 pin connectors on the board, or is it easier to get to B on the board?
If you can get to B then with power off, measure resistance first with key not pressed, then pressed.
