You are right.
Emitter to base Q601 is also .75
That is the rail voltages on the dbt, if those are STK pin 0 and 1.I had previously replaced Q601.
I did not have that replacement for Q603 so I lifted R601 and I now have balance.
34v and -34v.
34v and -34v.
Pin 1 19v Pin 0 32v
Is that the voltages with R601 lifted?
Circuit is unloaded..The IC and Q601 are out of circuit.
I know you have given me this lesson before, but the conditions are the same for both channels. Right channel works correctly.Circuit is unloaded..
So you feel desperado because your Technics is faulty: Poor, poor, pitiful me... You're no good ! you seem saying while removing the cover. But after your effort (It's so easy !), you can hear a voice asking Try me again !![]()
