Hard to believe as much as I have been into this I have not stumbled onto the solution by now.
Sorry 1013. I have a mess here.I put everything back in this morning. The original SA1123 is in prior to this morning is was a 992.
Those readings indicate it is turned on hard, and saturated, rather than shorted.Q601
E-C 93mv
E-B 810mv
B-C 710mv
That also makes sense from those readings.powered down it does not read as shorted.
Is the fuse F601 in place? If so take it out to isolate circuit from downstream influence.
That is what I was doing before I lifted the ribbon cable.
Yup, just doing a quick recovering of where we are at so I don't ask you to do something, and caution against something, to damage things further (including your wallet).Correct I have moved the components and the problem remains the same. I just want to let you know everything i can think of. The right channel always works. the left has never worked. I am ready to make any changes you can think of.
