eXpediency
If you do not have a filter electrolyte C16 half-wave rectifier (-31.3V) in the Led Driver, then you get the same effect with ripple at the mains frequency.No luck! I've re-hardened all the LED and connector pins on the front board, desoldered C16 (50V 220uF), cleaned the leads thoroughly with isopropyl alcohol, and soldered a new capacitor. Unfortunately, the problems persist. I even replaced the 6.8V zener diode D17 with an 8.2V one in an attempt to "dope" the voltage at pin 4 of J8 from -25.7V to -24.3V (much closer and within tolerance of the -24V specified in the service manual), but, damn it, I now get a voltage of -21.8V, and the ghosting on the display has remained unchanged. I think I'll have to face the facts and keep it as is. Aside from these two issues, the equalizer still works properly.
With proper power supply +5 for logic.
Compare with diagram in #33
