Great choices. You'll be very pleased with both.Well you've done it, my SL-1210GR2 is on its way to me. The VM740ML will ship out next week. I am psyched!
My 2 cents (and worth even less)This machine is a beast. Incredibly robust, and beautiful fit and finish. Any concern I had about it looking "DJish" is put to rest. I love the aesthetic more than many of the minimalist style tables that are out these days.....
DJ haters from the "Disco sucks" era.I will never understand the whole "... but it looks like a DJ turntable" phobia. Who has stated this? The list goes on and on......
For me, it's the slide switch and the strobe. But I'm way past it!My 2 cents (and worth even less)
If anything, the 1200 series looks more normal than anything, considering the long - term popularity and wide spread use. This was not just used as a DJ turntable, it was used in broadcast and home audio systems.
@Eddy1025 enjoy that wagon, I think it looks great.
After a while, I don't even notice the strobe or the pitch slider. My Plain Jane 1200 MkII has been very reliable.I think the DJ comments come from, most of all, many, many DJs use/used them, and also they are very plain aesthetically. Plinths have moved on from the silver industrial look and most now are designed to look good, even the Technics line, a very positive trend IMO.
Regarding the strobe and the repeat, seems like new TTs hardly ever have a strobe. My cynical assumption is that it's because the speed might be revealed to be wonky, but more likely it was a production cost issue and/or aesthetics. The repeat switch always puzzled me - unless the user wanted to hear the same 18 minutes of songs many times in a row it's kind of useless. I have never used one on either of the TTs I've had that came with the feature.
1300G is on my radar to replace my current ClearAudio table. Reseached the crap out of this table, but I'm at a loss with your "fly away" comment. Can you explain? I'd get a KAB dampener anyway with any Technics table I'd own. Thanks.Like I said else where I would buy a 1300 G if it weren't for the fly away arm. I am guessing that fluid dampening trough that Sky fi audio sells might be the perfect solution. But until I can audition one I'll stick with my TD 125 with a linear arm.
And the Neo-Belt Drives can do no wrong crowd. (The Linn LP-12, and Rega Brigade especially). I call the SL-1200 business like. The Black models look better in domestic environments (I own a SL-1200 Mk II in Matte Black, very attractive). It goes well with my Sansui 4000 receiver, and my Dynaco A-25 loudspeakers. It has had the interconnects upgrade (very late production, high capacitance cables originally fitted).DJ haters from the "Disco sucks" era.
Oh ok, yes I know the purpose I just didn't understand the "fly away" terminology. From what I've read you can't use the Lil Fwend with the KAB, not enough room to place after the KAB tray is installed. I'm waiting to see how much in tax I'll owe (15Apr) prior to the 1300G purchase. I've know the 1200G has a better arm and build quality but the 1300's motor noise reduction (sigma delta?) is very tempting and I'm surprised they didn't include it with the 1200G. Thanks Twiii.If you will go to Sky fi on You tube im one of their video Posts the Explain two accessories for Technics Turn tables. First is the Little Fwend end of record lift. The second accessory is the the damping system for Technics tone arms. Some manufacturers tone arms come with fluid dampening as part of the tone arm assembly. I think the vidseo is well done. I think the gadgets are shown with a Sl 1200 G, but if you look at the SL 1300 G video he explains the accessories will work with the 1300 G and 1200 GR 2 also. You just can use both.
The dampening fluid is similar to STP. As long as the arm doesn't move rapidly then it does not increase horizontal friction as the arm traces the grove. But rapid small movements are dampened. The idea is to reduce arm resonances. But what the fluid would do for me would be to slow the movement of the arm when I try to grab the finger lift when returning the arm from the end of playing the record to the rm rest and help me from placing the arm correctly on the arm lift for correct positioning over the lead in groove so When I drop the arm the arm doesn't slide of the side of the record. I have to be directly over the top of a record to align the tone arm for lowering to the lead in groove. Which is easy to do with the The Thorens and Rabco linear tone arm Align the stlus over the groove and push the tab. The Rabco lifts automatically and the end of the record and I just grab the shuttle from the arm and place ot in the out of the way home position and I am done.
The VPI Turn table is a totally different can of worms were I have to get down on one knee to alighn the stylus with the lead in groove and then lower the arm lift. Which is very smooth with the 10.45 inch ceramic gimbaled VPI arm. Lift ing at the end just requires using the arm lift. THe mass of the VPI arm is a bit heavier and for some reason the gimbaled bearing provide just enough friction as to keep the arm from wanting to leave my fingers. Where the lift on the 1300G was a bit erratic when dropping. So, I missed aligning the stylus correctly with the lead in groove. Because I couldn't look straight down over the headshell to get the correct placement. Plus I couldn't see any better because I could not see the the cartridge straight on. So touching the arm to get jst the right aligment was a very louch situation and the arm could fly away if I weren't very carefull. SME arms fron the 60's and 70's had a material on the arm lift that kept the arm from easily sliding along the lifting platform. Something the Technics 1300g Didn't seem to have, The vpi has some type of plastic material on the lift rail that when combined with the ceramic material of the tube of the tone arm presents some type of friction to keep the arm from flying away.
In all three cases even though the cartridges are with a gram or two in weight and mass, and all three are tracking close to two grams. The 1300 Arm for me can just have a tendency to not stay in place when being lifted by the lift rail. Then when I reach for it it just seems to want to take off on its own. It may also be at the amount of anti bias correction being applied to the arm to allow for best inner groove tracking at high velocities on my Ortofon Test record.
This has to be motor noise reduction on paper (math). The 1200 motor is one of the quietest I've ever owned.Oh ok, yes I know the purpose I just didn't understand the "fly away" terminology. From what I've read you can't use the Lil Fwend with the KAB, not enough room to place after the KAB tray is installed. I'm waiting to see how much in tax I'll owe (15Apr) prior to the 1300G purchase. I've know the 1200G has a better arm and build quality but the 1300's motor noise reduction (sigma delta?) is very tempting and I'm surprised they didn't include it with the 1200G. Thanks Twiii.
