TECHNICS SL-1200GR2
@twiiii Agreed the tonearm lift is a critical feature, especially for a lazy and also twitchy dude like me. I have an SL-1600 which is wonderful in every way, especially the way that low tech robot drops the needle exactly on target for me and then picks up the arm at the end as if reading my mind. The only way to improve this scheme would be if Technics made a changer version. One that wasn't $$$$ and ultra rare, that is.
I can also understand and appreciate the damping for the function you describe. But I am puzzled by the idea there is some Technics design flaw such that the tonearm will resonate and cause a problem without it. I continue to read how my turntable model is not that great but if I add the damper it will be much improved. I don't give those posts much credence, but I am curious: What does that system actually do?
Oh it's measureably proven (youtube videos) using Technics own provided data (8-12hz), the KAB reduced it to almost nothing. I was skeptical at first also. I realize motor noise below audible range is mute for some, but if a simple and cheap fix helps with that it must be doing something for overall performance. I came to the realization that expensive tonearms tend to use fluid dampening for a reason.
This has to be motor noise reduction on paper (math). The 1200 motor is one of the quietest I've ever owned. :idea:
Oh especially the new offerings, for sure, especially for what they're charging. I could be totally wrong, but the Sigma Delta circuitry kept popping up on the video's I watched. Buy the 1300 with the technology or pay $1K more for the upgraded tonearm and plinth density. I can't decide.
No, I believe you saw this, but even Technics is known for a bit of advertising hype. ;)
My tube phono-preamp hiss and record mastering completely drown out any motor noise. :idea:
Your Love Is King.
Off "Diamond Life." EPIC. 28-3P-545. CBS-Sony (Japan) pressing. 1984.
Run-out: 28-3P-545 1-A-12. 〄 C
No, I believe you saw this, but even Technics is known for a bit of advertising hype. :)
Your Love Is King.
Nice! Yeah I realize 8-12hz isn't something that's audible, but if a cheap upgrade can raise the tonearm quailty just a bit, why not?
This is one of the quietest LPs that I uploaded. About all I hear in the background, are the Raytheon 5751s. :) Subwoofers on. :thumbsup:
Look At You Look At Me.
Off Dave Mason's "Alone Together." ABC-Blue Thumb Records. BTS 19. Terre Haute pressing. 1974.
Run-out: T1 BTS- ̶1̶9̶- A-1 5045
My Ratheon 5751's are deathly silent in my Tube box DS2... the only tubes that I could hear any noise out of were a pair of GE-JAN 5751's
Oddly, the two noisiest in my rolling experience were a Miniwatt (Dutch) and a Mullard (Blackburn) ECC83. Both tested high but had high floor noise, too.
The OEM TungSol (Russia) 12AX7 was quiet but had poor sonic separation of instruments, it had an unfocused sound. I almost returned the Phono Box because of that, but decided to try other tubes. The unit is quite sensitive to the tubes that I rolled. The second-best tubes were the Sylvania black plate triple mica 5751.
This Sylvania.
I think the delta-sigma thing is not about acoustic noise from the motor, but rather about electrical "noise" that could affect the rotating speed of the platter (or rather its constancy). It ensures that the electric current that's fed to the motor is as clean as possible, to prevent any speed variations.
This Sylvania.
I have good sound with a pair of JJ E83CC (short plate frame grid) and a pair of the new Psvane Horizon 12AX7. I tried a pair of JJ ECC803 (long plates) but didn't like them as they were kind of "dark". The GE-JAN 5751 were the worst sounding ones by a country mile- almost shrill.
I never tried the JJs. I stopped at the Raytheon. No other tube has been in the pre-amp.
For my system with the old-school Alnico magnet speakers, it was positively the best.
I was unable to find a YouTube video test on the damper but there was a member review in Audiogon that was the usual audiophile unquantified improvements, harder hitting bass, etc. I saw it was $149 which IMO is not very cheap, but could be worse.
The gimbal for all tonearms is designed to pivot with as little friction as possible. I can't see the physics of anything that adds resistance to the gimbal improving performance. If anything it is an additional rotational resistance which requires the record to exert more force on the outer edge of the stylus to move the arm gradually closer to the center as it plays, basically in the same way as antiskating adjustment. It doesn't add any mass to the tonearm according to the spec, and it doesn't add any stiffness or other material changes. So how does it change the resonance? Perhaps by adding weight to the tonearm assembly/mount?
My tonearm measured 8hz with the AT VM95ML on the Shure test album. I can't hear anything at that level. It's good enough for me but certainly if it satisfies the tweaking urge that is a valid reason to have one.
I get much more use out of my Audio Technica Safety Raiser (lifter) than I ever would with the damper, and you can't use both at the same time.
