JP
7480 74111110101115
You do like to make yourself out as the only expert in threads JP and you are far from it. One of the best Techs is Warren IMO on another forum, I believe he was a Tech for Marantz for many years. Not doubting you know a bit about SP10's but you are far from a world authority on them or are in a position to cast dount on others ability. What Warren has done to his is mind blowing especially is latest inverted bearing.
4 tables at random over years is not extremely small sample size. If basket cases were common then either I have been extremely lucky or the other possibility is SP 10's with major problem are not as common as you say as it would be statistically very unlikely to get 4 good ones.
That's one hell of a non-sequitur.
The condition of the units I've seen didn't change based on my personal experiences - they are what they are. If people can add data that can be "validated" to that sample pool, the more informed the community becomes. That experiences differ, especially with small sample pools, is not remotely surprising.
If we want to turn anecdotal reports in to data we need a way to validate the anecdote. A criteria that, in this case, good/bad is being assessed in a compatible way. My asking the question didn't cast doubt, it's your refusal to answer the question that did that. Just as it was entirely up to you to create it, you're also the only one that can remove it.
In turn you've decided to resort to an ad-hominem in your last sentence. Why? In light of a larger data set shouldn't advice be reassessed with the new information? If you think there's an issue with the data perhaps try to qualify it? I note that your report inferred that three of your units spent their entire lives in Australia - the driest climate of any inhabited continent. IIRC Jon (that's his name) has reported similar findings with a slightly larger sample pool than yours.
I follow data, and my advice is based on that data. When new data is presented I validate it, incorporate it, and reassess that advice. My knowledge of these units has grown over time, and if you look you'll find that I've changed my position on a number of items related to them over the years, all due to learning new information.
And yes, Jon does make very pretty parts. What does that have to do with this?
