Anolsos_1974
So, I have found at least one culprit - one of the pins was loose in the power pack, and probably rubbing intermittently against the connecting bit of the circuit board causing the drop in sound from the left channel. I think the other pin came off when I was removing the power packs. But nonetheless, at least one was not attached properly. Replacements seem around €13 (~$10?).
I have a couple of queries though, the 'power pack' units, look similar, but not identical. Am I imagining things? Also, is it really going to be as simple as changing this out? As I mentioned above, when you pushed down on the power pack with the loose pins, it sounded lovely...but any advice would be welcome before I go any further.
