@jeromach: sorry for thread-hijacking, but now that you mention Icq: how do you adjust this with high power amps?
I have an SE-A3 in which I've aligned everything - except for the level meter (no scope at home, but nvm) and said Icq, as I don't have dummy resistors rated for 300W.
The 8077 btw uses a clamp and it might not be easy to find a proper replacement, since it needs both be wide and high enough. But I just checked what for instance Digi-Key has available and most likely all of these will be ok (I looked at 12k uF too, that would be an upgrade, although probably not really noticeable); http://www.digikey.nl/products/en/capacitors/aluminum-capacitors/58?k=&pkeyword=&pv13=63&pv13=75&FV=4038d3,fc01ac,fc01c7,fc01d1,fc01eb,fc01ed,fc01ef,fc01f2,fc01f7,fc01f8,fc01fc,fc01fe,fc026b,ffe0003a&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
If the diameter of the old caps is 40mm than it would probably be best to take one of 65mm high, then it will probably fit the clamp nicely. Then these two would be the ones to choose;
http://www.digikey.nl/product-detai...nics-cde/383LX103M080N062/338-2034-ND/2256635
http://www.digikey.nl/product-detai...nics-cde/382LX123M080N062/338-2109-ND/2295339
Please take note that all of these are "Radial, Can - Snap-In - 4 Lead" versions, these will fit the existing print without modifications. Also, please check all sizes before ordering, my recollection of sizes might be wrong!
Thanks! It's the first version (the MK2 is too rare…). I too have the service manual for it, and I know that I'd need a scope and THD meter to align it properly. However, the SM also says I need dummy load resistors…Is this a MK1 or MK2? I have an SM here of the SE-A3K, presumably a MK1. To adjust this one an oscilloscope AND a distortion analyzer is needed. I wouldn't know of a way to do it differently.
This thread makes me want to dig up my old SU-8099 and recap it.
