Does the amp still work? And if so, is it ok (or having some minor glitches, which mostly is no real issue to fix)?
There are some things that need to be replaced/done without any question;
To start with, a word of warning; be very very careful with the thermal diodes mounted on the two rear power transistors. Do not bend the leads, they tend to break and the part is nearly impossible to replace (the same goes for the SU-8088, but there they are mounted to the heat sink)
The trimmers right in front of the large filter caps need to be replaced (do NOT - I repeat NOT - try to adjust the old ones, this might blow up the power transistors).
The double transistors 2SA798 and 2SC2291 need to be replaced (Q301, 2, 3 and 4) - you need to use two normal transisors per double transistor and match the new ones (when you're there I can explain how to construct them)
Check all solder connections for bad ones, remove the old solder and apply new.
All switches need to be treated with de-oxit. This does not always work satisfactorily, they then need to be taken apart, cleaned and greased (ask for instructions before dismounting them).
The contacts of the relay need to be cleaned or the relay just replaced
As for the electrolytics, using Nichicon gold for all of them, except the large filter caps, will be ok. Panasonic FM will also do the job nicely.
The large filter caps is optionial if they still measure ok, but if you do not have the tools to do so, it is better to just replace them. Panasonic will be fine, but stocks run out or have done so already, since they stopped producing them. Cornell Dubilier also has nice large filter caps. The diameter is important to fit them in the existing brackets, new caps are smaller, but by just taking a cap with a higher voltage it must be possible to get the correct diameter.
Here's a cap list;
Column 3 and 4 is what is stated in the service manual, column 5 and 6 is what actually came out.
