Tekton Owners Thread
Ok dylster, go ahead and order the Decware Torii mk IV. Right out of the box it's amazing and a perfect match for the DI's. I got the black figured base and it goes with my Mercedes Diamond Black DI's perfectly......your girlfriend will appreciate that ;) In a month I'll be able to better appraise it after its broken in some, but I'm very happy with it already. I am using all NOS tubes instead of the Tungsol output, input and rectifiers it came with and I think the warm, liquid sound of them blends well with resolution, speed and dynamics of the amp. The DI's are happily conveying the magic the Torii puts forth......but then they sound great with any good amp driving them. I still want the Kismet Monoblocks for some concert sound level rock! The option of tubes or SS would be sweet.
Where on the blog did you see it butchgo? I see the Orange Pendragons he has available but nothing about a new speaker.......and inquiring minds need to know!
Thanks Zenith. I see them now, the white speakers next to the orange Pendragons. Eric's version of the perfect speaker for small SET amps. Very interesting.
Anyone using the theater setups? I am intrigued by the mini Lore set.
I had Eric build me a matching center channel to my Lore Reference towers, i don't have space in my room for the surround channels that big or the even slightly smaller mini lores. So far i'm really happy with the CC, dialog is very clear and natural sounding.
@ictwoody ...let us know when you grab a pair of those new 'Perfect SET', I see your wheels already spinning lol.
Ha! You must have seen my comment. I just want him to post details... I'm not really serious. My Altecs are already pretty SET friendly and I am content with my Pendragons as well. Some days I shake my head at myself at how good my 2nd and 3rd systems are. I'm blessed.
- Woody
I hear you, seems like you've already got a nice little collection of gear going. I'm curious as to what makes these new speakers "SET" friendly? Or much different than his current range of speakers. All of his designs are pretty efficient as is and many people are already using low watt tube amps to drive them.
I was thinking the same thing Msas. I've been using small tube amps with great success with both the Enzo's and Double Impacts. It will be interesting to see what makes the "Perfect Set" differant from the other Tektons.
Sitting here listening as I type, I can't recall owning speakers that the music seems to eminate from around them as much as these Lores. They also place a strong center image which is funny because I have a center channel staring at me and you'd swear it was on right now
Been playing with my new dragons and after a month or so of tinkering around, I believe I have them dialed in on full flames. Here’s the setup history:
Started out with Airport Express Gen I (AEX) using its internal DAC and listened carefully for awhile. The AEX did fine considering the fact that iTunes down-sampled everything to 44.1 KHz. The dragons played well, but preferred higher quality recordings (ALAC and 320 MP3) to anything else. When the quality went down, the dragons felt quite tame and somewhat sleepy.
While continuing to use AEX, I switched to Fidelia and Audirvana Plus players and pumped the signal out via Airfoil just to bypass the annoying iTunes’ down-sampling routine to see if there was any improvement in sound quality, To my amazement, it was. The same audio files sounded noticeably better and the dragons registered the change with an uptick in performance. At this point, I was pretty happy with the sound and was confident that I made a good choice with the Pendragons. However, I wanted to see if I could squeeze more out of them since many people have reported that they can compete with speakers costing 3 or even 4 times as much. So I decided to push them further.
I brought in the cavalry in the form of my trusty Stello DA220 DAC. Well, that brought in a significant improvement in sound quality, but most importantly a separation of instruments. What AEX jammed together through its internal circuitry, was now clearly separated via its toslink connection to the dedicated DAC and the dragons were happy to broadcast this most welcomed change with a significant bump-up in staging. At this point, I was even more satisfied with squeezing this level of quality from the notoriously cold and harsh ones and zeroes. However, for some reason, I decided to push the envelope further so I went out and got me a Raspberry Pi 3.
This is where the pain started. The RP-3 runs its own flavor of Linux and it does work well as a little learning device which was what it was built for. Well, I decided to turn it into a music server and use it to pump out audio digital goodness directly into my DAC via USB. This was really hard to do because the Raspbian OS was fighting back every step of the way. Lots of tinkering, patience and two weeks of my time went into this project, but in the end, I was able to accomplish what I set out to do. So here is the final leg of the journey.
The RP-3 is now wirelessly grabbing music files stored on my main computer and without any monkeying around (hello Apple, are we paying attention here?) is feeding them into the DAC directly via USB. The DAC does its job and is converting the raw data into a quality wave signal that is sent down the chain for amplification. This is where the Pendragons come alive. They really sound like $10K speakers and I’m not exaggerating here. Because they are so sensitive and can deal with low level amplification, they can do things that many other speakers simply cannot as long as they are given quality signals to play with. Let me just say that there are sounds in my music collection that I’m hearing for the first time in my life from music icons such as The Beatles. Led Zeppelin, Elton John and The Eagles, to name a few. The most stunning part was that I actually fell asleep during Bon Scott’s screaming which never happened to me before. That is what the dragons are capable of. Sounding warm and relaxing in the midst of an AC/DC ear drum-assaulting ruckus. Pretty amazing!
In closing, the Pendragons have everything a well designed speaker should, but they do demand a lot of effort in the setup department and quality amplification in order to sound their best. For those brave enough or crazy enough (like yours truly) to try, the rewards and satisfaction will transcend this newly discovered music experience, not to mention the meager $2K Mr. Alexander is asking for these audio gems. IMHO, they are worth $4K without any questions asked.
Great write up Naimster. I've found the same to be true with the Double Impacts, they will reveal whatever improvements you make upstream of them. They have made me rethink my whole system and I'm fully realizing the very improvement I've made. The first was the Decware Torii mkIV amp. It's such a revealing amp that brings forth music from my CD's I previously didn't know was there and does so in such a natural and realistic way. The Double Impacts are thriving, taking everything the amp can throw at them with ease. I never realized just how big a soundstage can be and with the Torii and Double Impacts I'm getting a 3-D holographic stage that is sublime. To take things a step further I just picked up the PS Audio Perfectwave Transport and DAC......dear lord, I'm in audio heaven. I've reached audio nirvana and I find myself smiling while listening to all my CD's all over again. Tekton speakers can hold their own within any system and will really show their true worth the more you improve your equipment upstream from them. Having said that, they still sound great in modest systems, such as in my small theater system.
Totally agree. I’m enjoying my music collection all over again. I still don’t quite get how it is possible to get this kind of sound from these speakers, but I’m not complaining. They are a rare find indeed and your DI’s are even more sensitive so there are endless options for setup and experimentation with various components. I’ve always thought that speakers are only as good as the components they are made of, but Tekton has changed that perception. Fancy crossovers and kevlar drivers are not what gives the speakers the top edge. It’s the whole package including the size and tuning of the cabinet because the secret sauce is in tonal balance. I’m convinced that big sound cannot come from small speakers and that is Tekton’s take-home lesson for me. Harbeths, old school Tannoy monitors (or any other speaker in their size and class) can never sound as good as the Pendragons or Double Impacts even if they were wired with solid gold wire because they can’t move air. Air movement is essential to tonal balance that goes beyond a good hi-fi sound at any power level whether 3 or 300W. After my Pendragon experience, for me personally, monitor speakers are dead, as are amplified subs.
So true naimster. When researching speakers I came across so called speaker design experts on forums expounding on how Tekton speakers couldn't possibly sound any good based upon their design. Of course none of them actually heard them and thankfully I paid them no need and ordered the Enzo's. For me tonal balance and dynamics are what makes music sound real and Eric has hit the proverbial nail on the head with both. That's not so say they lack any of the other audiophile traits like imaging, soundstage, resolution, etc.....as they excell there also. Buying the Legacy Audio Focus SE's made me realize just how good Tektons really are. The Legacys are great speakers and had I never heard Tektons I would have been happy for life with them but they lacked the dynamic slam of the Tektons and therefore sounded less real to me. The Legacys had a high end that had more air and were slightly more detailed, but I couldn't live without that live sound Tektons have so I kept the Double Impacts and sold the Legacys ( at quite a loss) and am done with the speaker merry go round. I would have never thought the $3000 Double Impacts could come close to the performance of the $12,000 Focus SE's, it doesn't make any sense. I'm not learned enough in speaker design to make sense of it but Eric is and thats enough for me. I'll just sit back and continue enjoying them......and smiling while doing so :)
Mac, couldn't agree more! Loving these DIs!!! It just amazes me how I can still get a tactile sense of drums with the volume set very low! :beerchug: By the way, has anyone heard if Eric is planning to build a batch of grill cloths for the Double Impacts, anytime soon? Currently, I have them protected with a couple of fireplace grills, but I think they'll look better with the speaker grills installed. Thx!
I’ve been thinking of adding dual subs alongside my Tekton Lore mains. It will be for music only, in a 12x15 room with a 9ft ceiling. Has anybody heard these? Do you think it’s overkill? No online reviews as of yet.
http://www.tektondesign.com/enzosub.html
They seem good value and may have better synergy with the Lores than something at a similar price point like SVS PB2000, Rythmik LVX12, etc - but then those companies are tried and tested when it comes to subs?
