Fisher 500-C draws 275 watts at full power.
To be honest, ANY piece of vintage gear you buy these days is going to need some work These things are 60 years old. If the transformers are good then it can be restored, but can caps, coupling caps, switches and pots are probably all going to need some work. The tuner section may be out of wack. The parts are obtainable and aren't that expensive, but if the unit has never been worked on, I seriously would not expect it to be in plug-n-play condition. Again, if it's all original and hasn't been serviced in the past 10 years, I would expect to spend $200-300 to have it checked out by a reputable tech.
