So we are still not getting signal through the 19KHz/38KHz chain. Well, dig the scope back out and look at the collector of Q402. You are looking for a 19 KHz signal/ so sweep rate 50 uS/div.
First decent looking trace I've seen.
This should look like a full wave rectified signal with a frequency of 38 KHz. Amplitude depends on the turns ratio of the transformer (L405). but I would expect about 3 volts peak. If not, then use your ohmmeter to check the continuity of the secondary of L405.
Bummer. Well, you are going to have to repair one of them then.
Do I understand that the transformer that was in the unit had an open secondary? That neither of the output pins rang to the center tap? That would require two internal windings to be broken.
And the one you removed from the parts board has an open primary?
I have repaired these on occasion, but there are many variations of what it might look like internally. The most likely place for a winding to break would be where the wire is wrapped around and soldered to the pin. Take a good look at one of them (probably the one from the parts board) and figure out how the coil assembly is held into the case. Usually it is just little indentations near the case mounting pins. Carefully remove the coil assembly from the case. A picture would be nice. Then use a magnifying glass and look at where the wires come out of the coil and connect to the pins. Try to see if you can find a break in the wire.
Yeah, that wire is going to be mighty fine. The configuration of stereo decode used here is so common, I would think that coupling transformer would be ubiquitous. Gotta be used (or a near variation of it) in thousands of different makes/models.^^ done that before, often if its going to break it will be right where the wire connects to the pin coming out of the transformer. Makes for a fairly easy repair in low freq parts. Doesn't go so well in radio bits.
Don't want to rewind a couple hundred turns of #43 wire, huh?All coil leads attached to pins (verified with 10x magnifier). Opens are internal to the pins just as Whitehall's tech said. End of story, I guess. Time to try and find one on Barter Town.
We would need one good winding with a center tap. Everything seems to be resonated with a 4.7 nf cap, which would make total primary inductance about 15 mH. What coil do you have?I have a coil with a good side. The induction might not be the same as the coil it will replace but will it be "good enough"? I doubt it.
