With these Edcor transformers an there high frequency performance you can
certainly use LOOP feedback(from the output side of the transformer back in)
and it will be stable, my main design with these single ended amps is the use
of the UL taps and Local Feedback,(schade style) then loop isn't "needed".
I prefer not to use loop feedback when the design warrants it, from both the
technical aspect, and I prefer the sound without loop feedback, but one sure
can use loop feedback if they want to.
Also using a higher primary, 5k verse 2.5k, will need less feedback to "control"
things, there are multiple ways to get the end result, one isn't necessarily any
more proper then the other, it often comes down to ones design philosophy.
(again here though, at these voltages and currents, 5k is still the better load)
