katabatic
Member
Choke question...
OK, so I'm planning to build one of these puppies, using the Antek AN3T275 and ss rectification. The Radio Daze 8H choke doesn't seem to be available anymore, and I've been trying to come up with an alternate power supply with reasonably-sized Hammond choke(s). I'm assuming (and this is question #1) that, since the grid current of a single 6LU8 is listed as 20ma in the RCA manual, the 75ma available in the 5H Hammond 156L choke should be sufficient, and I don't have to match the overall 108ma draw of the whole amp when using choke/cap filtration (which would mean using the giant-ish 157M or 159Q). Assuming it is, could someone pls. look at the attached 'possibilities' to see if they might work (one uses one choke, the other two)...also please shout if I've screwed something else up; PSUD2 is not my strength.... Thanks in advance for the help; this should be a fun build.
George
George
