Here is the PCB info... part list and schematic, all pretty cool stuff.
Its going to be a few weeks before I get a report on the bench test.
I ordered up some tubes from AES and a new PCB from Mr. Chong. Im thinking of using the bigger Edcors next time.
(thanks for posting) I saved it..
Hey double check your cathode resistor on the output tube,
there may be a typo on that schematic. (but might not)
(if running full screen voltage)
It should be between 680 and 750ohm, depending on plate V.
If your running the 180ohm listed there your running the tubes
into meltdown territory. But since it's running zeners to drop V
it will be different and draw much less then our original.
(so can you list your plate an cathode voltage)
Other then that and not having that feedback scheme wired, I
see nothing that looks out of place, one tweak I'd probably run
is drop the cathode resistor on the driver down to 680 verse 1k.
One last thing, I would suggest an larger H choke then the 1.5H
suggested in the PDF, something like at least 6H but more 8H, +.
(If trying to use a single LC stage, multiple you could use a 1.5H)
The RadioDaze choke used in the original build would be fine there.
