Hi Guys,
I've been working on the input stage of the C-3, trying to improve it.
Just for info, that stage was originally using a pentode 6AU6. I found it noisy so I converted it as a triode with great result.
Then I wanted to try a genuine triode as a test, for even reducing the noise a bit.
I found the 6AV6, a good triode also 7 pin which was a good candidate. This tube is 1/2 of a 12AX7.
After some research I came up with this design, using a led instead of a cathode resistor + bypass cap.
The simulation showed a much better response in the low frequencies, thanks to the led with no dynamic resistance so no bypass cap.
The highs for the audio spectrum were pretty much identical.
Here what the freq response looked for the 6AV6 on the left and the 6AU6 as a triode on the right.
Then I did implement the 6AV6 in one amp and gave it a shot.
On the bench here are the 2 actual amp bode responses, 6AU6 on top and 6AV6 at the bottom.
As the model predicted, the actual amplifier measured as expected. Better low response, mids and highs identical.
Now on an actual listening track here is what I have done.
Same known track, played in mono to both amps, and I was listening each amps one at the time.
I had to adjust the balance level and the 6AV6 had much more gain.
First the 6AV6 had more white noise than the 6AU6. I was expecting the reverse. So kinda disappointed.
That aside, I can't tell the difference.
Both are totally excellent, and I can't honestly say I have heard a change.
Maybe, I say Maybe the highs were better with the 6AV6 but I am not even sure.
And the lows are identical to my ears, despite the 6AV6 showed a better low response, but so low in the pectrum that it really does not make a change to human ears, left alone my old ones in particular after decades of heavy metal
So as a conclusion, unless someone sees something obviously wrong with my test, I think I'll pass on implementing that modification as it really does not pay off.
Thanks for reading guys.
Brice.
