Main bearing lubrication
The Technics SL-7 is off topic because it's a P-mount SLT design, but anyway here is my advice.
All turntable main bearings are very, very, tricky to properly lubricate so as to not make scraping noises. The fact that they rotate so slow does not allow a proper continuous, unbroken, and radially rigid lubricant film to form and build a positive condition known as hydrodynamic or fluid lubrication. Instead we are left with a lesser lubricating condition known as boundary lubrication.
Since the physics of proper boundary lubrication are fairly complex and demanding to implement properly, I recommend not altering or adding what you may think is the ultimate lubricant to a main bearing unless it is surely determined there is excessive scraping noise or that the level is significantly low as in the case of the very few turntables that allow adding oil via a removable spindle cap. Even then, the lubricant of choice and your procedures must maintain immaculately clean protocol.
Even if you determine that your bearing is making abnormal noise, you are in for a real roller coaster ride in getting it to quite down. This is a complicated subject.
Bottom line; don't lubricate a main bearing unless it is making noise beyond the norm.
Best wishes, Professor Bizzt
Oh dear, disaster at the cricket, but, back on topic, I've serviced my SL-7 but am wondering whether I should apply some oil to the spindle/bearing.
Your thoughts, please.
