Plinth physics
Hello Professor;
The plinth hopefully provides a sonically inert, stable, and secure platform for the playback components. It should be sufficiently rigid to ensure consistent proper alignment relationship between arm axis/traverse plane and platter surface plane under normally encountered conditions. Damping should be sufficient to suppress resonances and microphony. Mass should be sufficient to suppress acoustic LF/feedback and seismic VLF interaction with pickup arm/cartridge LF resonance. Mass distribution is usually balanced to be equal on the support footings. Requirements/need for suspension are dependent on environment of use plus above factors subject to basic philosophy of a given designer, there is a world of difference between a Cotter 3-point suspension and what is generally done with an ambitious direct drive "Statement" TT.
Then again I could be way off-base on any/all of the above.
Hi Pio1980,
You and I seem to be almost the only people on this thread lately. Where are all the respected engineers responsible for the creation of these interesting machines and the mad scientists who explore the inner workings of them? Oh well, I guess that's asking too much. I guess us amateurs will have to do for now.
I really like your statements on proper plinth design, but please allow me to put this into my own words at the risk of repeating what you have already said. If I'm wrong or have omitted something please tell me. I am only human.
Here are the ideal qualities as I see them without concern for what can actually be achieved or for what is practical:
Plinth:
The plinth (fundamental platform that all components are mounted to) should be
infinitely rigid. It should be so rigid that any energy entering it from within or without is reflected back to the source with 100% efficiency.
Since mechanical energy attempting to enter this hypothetically ideal plinth would find no home in it, it would be rejected and reflected back to where it came from. The plinth could not be set into any form of sympathetic vibration whatsoever as it is closed to accepting any energy at all.
The utilization of this perfect material would of course address issues of rigid geometrical relationship of tonearm and spindle. Perhaps a diamond, rhenium diboride, ultrahard fullerite, aggregated diamond nanorod, or some other super-hard material would approximate these ideals.
One should also use this perfect material for the tonearm, headshell, and cartridge body because all mechanical energy should be prevented from traveling any further than the cartridge's elastomer cantilever suspension. This would require a highly advanced cartridge suspension that eliminated or minimized energy reflection back to the stylus via the cantilever as this could adversely impact the already difficult job the stylus has in tracing the record groove.
Why should the plinth have this extreme level of rigidity? Because an otherwise top quality plinth utilizing linear high-bandwidth damping accepting just a portion of a waveform of mechanical energy has already seen the beginning of performance compromise. Under these conditions, it is too late to claim perfection.
Plinth mass, mass distribution, and suspension:
The plinth mass (in conjunction with the suspension) should be large enough so that any mechanical energy of any frequency that the environment is normally capable of generating will be prevented from entering into the infinitely rigid plinth via a suspension tuned to a lower frequency than any frequency normally present in the environment. The plinth mass should also be sufficient enough so as to not react to servo initiated motor torque corrections. The plinth mass distribution should produce a maximum of polar moment of inertia and therefore should be concentrated to the periphery for maximum resistance to torque reactions from within as well as without.
Suspension damping:
The suspension should be damped just well enough to prevent excessive cycles of movement at resonance. Damping further would detrimentally widen the Q of the fundamental suspension resonance and allow more unwanted energy in from the environment.
Suspension linearity:
The suspension should only allow stable, simple, harmonic free, and vertically symmetrical movement of the plinth at fundamental resonance. It should not allow the plinth to move in any manner other than this. Each suspension compliance should not allow frequencies higher than the fundamental resonance to pass through its structure. This often happens with undamped metal springs exhibiting a longitudinal mechanical energy conductance condition at frequencies higher than the suspension/plinth mass fundamental resonance.
Best wishes, Professor Bizzt
