Is the PL-L1000A a piece of junk?
Hello DCinDC,
Thank you for your question regarding the Pioneer PL-L1000A.
First off, despite my admittedly strong and sometimes emotionally charged ability to open my yap and insert my hoof regarding opinions I have acquired from the road-of-life over the years, I still try to be careful what products (or other things) I call a "turd" until I have had a chance to look at things a little more objectively.
I have clearly stated in this thread that all the SLT turntables discussed here should be carefully calibrated and maintained. I don't remember for sure without reading through this whole thread again, but I thought I also stated that the Pioneer SLTs should be closely examined for build tolerances, as I have found issues like skewed Cadmium Sulfide sensors (or CdS sensors for short). To be fair though, this CdS issue should only effect the amount of tracking error, and not the the arm's nominal perpendicular alignment to a radii from the spindle. Again, that is mostly addressed by the calibration.
All of the SLT service manuals that I have worked with so far contain a few errors, and the Pioneer manuals are not the worst! None of the Sony or Pioneer SLT service manuals mention anything about using precision jigs to calibrate these tables to a level of accuracy that would be expected by the normal audiophile. It is possible to experience issues like you mention if these jigs are not used, and I have no idea if Pioneer used assembly jigs for tonearm construction and calibration at the factory.
Perhaps the fact that someone has seen or heard about Japanese 1/2" mount SLT turntable tonearms performing sub-par has caused them to spend a lot more on some other more basic and traditional turntable option. I think that writing off a higher-end Japanese SLT because of this could be considered a premature conclusion.
I am aware of the Marantz SLT turntable (SLT-12?) you have. I have read about these, but I have never worked on one. I have no reason to believe that this vintage turntable will outperform the turntables discussed here, provided the turntables discussed here are operating as intended.
Best wishes, Professor Bizzt
To the Prof.
I bought a PL-1000a new in Europe. It would not keep the tonearm perpendicular to the rails. I returned it, not knowing why it did that. Others in my unit experienced the same. Since then I've considered it a turd. If you could speak to that I would be curious.
I now own a Marantz SLT. Do you have any experience with those?
edit: Pic is not of mine, just added it for reference.
Hello DCinDC,
