Plinths, state of tune, and tonearm design
Interesting points you made about plinth rigidity and mass. Sounds very similar in a number of key respects to what Kenwood's engineers were trying to achieve with the L-07D's plinth (though of course that turntable came as standard with a pivoted arm). I've always wanted to get my ET-2 onto my L-07D; just never had the time.
I agree completely with your comments on the need to make sure any complex, vintage turntable is fully overhauled. I collect SL-7s, SL-10s and SL-15s (though I realise their arms are semi-pivoted and T4P), and while they may have a degree of tolerance to maladjustments and aging problems, they sound a lot better when properly sorted.
Cheers, Jon.
Hi Jon,
We hear a lot of talk about damping in the audio industry, but what about rigidity? If we have a plinth that is so rigid it cannot sympathetically vibrate due to incoming energy from the tonearm and the environment, is that not better than a less rigid structure that allows sympathetic vibration but damps it quickly?
Of course these ideals (like I have already stated) are very difficult to impossible to achieve in a real world turntable plinth for a reasonable cost. Perhaps this will change in the future though. Having said this, the next best thing IMHO is to make it as rigid as possible, but damp it extremely well so that energy is killed off
ASAP.
There are those that would say I am wrong about this because that would destroy the "life" of turntable's sound making it dull and lifeless. I suggest that too many audiophiles are gravitating to "lively" or "euphonic" sounding equipment and are not understanding that components exhibiting this "life" are actually substandard in their energy management characteristics. I agree that there exist certain "lively" sounding music reproduction components that sound good, but good and accurate are two different things and the two should never be confused.
Although this thread is supposed to be about 1/2" mount SLT turntables and not T4P SLT turntables; my thoughts are, that although I have a lot of respect for Panasonic (Technics), I am a little uneasy with the idea of mounting a tonearm into a dustcover.
The dustcover is anything but an inert, rigid, and damped structure. Of course this is
not the ideal structure to mount a tonearm to. The fact that the dust cover is also of relatively large surface area acting like a microphone diaphragm does not help things either. To be fair though, Technics did manufacture at least one non-dustcover mounted T4P design called the SL-M3.
Air bearing SLT tonearm designs are great for maintaining almost perfect 0 tracking error across the whole record, but the compliance effects of the thin air film bearing concerns me. The super low friction is also commendable on an air bearing design, but how low is low enough? Finally, what about the noise of air escaping the gap. That is an issue that has had some noteworthy attention devoted to, but is this not an issue that is of serious importance when the design goal of the tonearm is to be as utterly dead quiet as it can possibly be?
Jon, you mention the term "semi-pivoted" here in regard to tonearms. This should be discussed further. SLT servo drive tonearms are used in all of the turntables listed in the first post of this thread. They
all use what might be called a "semi-pivoted" tonearm. The tonearm pipe pivots in the horizontal plane on low-friction horizontal bearings like any normal pivoting tonearm does, but the difference is that the arm pipe is connected to a sensitive tracking error sensor that tells the carriage drive electronics to move the carriage so as to maintain near 0 tracking error.
The models listed in the first post will all have slightly different tracking error accuracies, but I think it is safe to say that, assuming there are no problems, the tracking error is respectably low. There are those that have said in other posts on other sites that SLT tonearms cause the stylus to constantly drag on the outer groove wall. This condition will be no more likely in a properly functioning SLT servo tonearm than it would on any top quality pivoting tonearm and therefore this accusation is patently false.
Best wishes, Professor Bizzt
